BRAKE Noises + E Brake light - HELP!
Me again with some more problems:
Weird sounds come from the rear brakes when I step on the brakes. Had mechanics check it, but they don't know what it is. The noise is related with the ebrake cause when I brake and the sound begins, I play around with the ebrake and the sound stops.
Also, my ebrake warning light (the one in the gauge cluster) does not light up when I pull the ebrake. It is not the light itself cause it does light when I turn the key to ignition position. Is the a switch, sensor, or something that can fix that?
Once again, thanks for the inputs.
Possible problem
MaximaDrvr
Aug 19, 2015 08:20 PM
