aiming headlights
Old Mar 6, 2004 | 06:15 PM
sk24iam's Avatar
aiming headlights
I read the how to on how ot aim your headlights, but it doesn't say hot to adjust them on our cars. How do I do this?
Old Mar 6, 2004 | 06:32 PM
Conrad283's Avatar
I need a truck
There is a black 8mm extension on the lower outer part of the headlight ... just get your rachet, extension and a universal adaptor (to ease in the process on the passenger side). Just turn it until you reach the ideal headlight height.
The black 8mm extension in the upper inside area with aim the headlights right to left
Old Mar 6, 2004 | 11:07 PM
happyricefob's Avatar
V^___^V
http://www.autooptiks.com/aiming.html
Old Mar 7, 2004 | 07:26 AM
WHOS UR DADDY's Avatar
I tried this before, didnt see any difference.
Old Mar 7, 2004 | 11:46 AM
sk24iam's Avatar
In the fog I noticed my lights aimed up. This is wrong right?
Old Mar 8, 2004 | 05:51 PM
sk24iam's Avatar
Didn't the beam adjust?>
Old Mar 8, 2004 | 07:30 PM
ohannon7's Avatar
I just got done doin this about 30minutes ago after reading this thread. Ive been meaning to do it for awhile b/c the unevenness of the 2 headlights was driving me nuts. I drove it to a closed buisness w/ out alot of lights in the parking lot, turned lights on the wall, and got out and leveled them, much better now. Do like Conrad283 said.......
Old Mar 8, 2004 | 07:39 PM
V^___^V
The adjustment bolt closer to the parking/corner lights (outboard of the vehicle) is for the up/down aiming of the headlamp. The one further inboard is to control the right/left aiming of the lamp. You'll need a 10mm wrench to perform the aiming task.
To do the height adjustment, park your car so that the headlamp lens faces are about 25 feet from a wall. This wall should be perpendicular to the ground and level in all aspects. Measure the distance from the center of your headlamps to the ground. Mark this dimension on the wall. From this mark, move down 3.75" to 4" and make another mark. Begin to turn the adjustment bolt so that the centers of your low beam patterns land on that second mark that you made. As for your right to left adjustment, mark the centers vertically and aim so that they point straight out. Bear in mind that sometimes adjusting the right/left bolt can change the setting of the height adjustment slightly.
By the way, the foglamps can be aimed the same way. The foglights are 8mm.
Credit: Albertt and j-95G (for the foglamp info)
Two really good articles on aiming of headlights and auxiliary lights:
http://lighting.mbz.org/tech/aim/aim.html
Old Mar 8, 2004 | 07:57 PM
Conrad283's Avatar
I need a truck
Thank You ...
Certified, it works trust me. You have to make sure you have the right tools, it's an 8mm socket. Go to a dark parking lot with a at least 4 foot wall. Turn the lights on against the wall and turn the extensions coming from the headlight and watch the beam go up and down
Old Mar 8, 2004 | 08:13 PM
ohannon7's Avatar
I had to turn mine a few times till they actually started to move, once they do its obvious, cant miss it
Old Mar 8, 2004 | 09:52 PM
DAVE Sz's Avatar
Hooooooonda.....
I thought they weren't supposed to be level? The passanger side is SUPPOSED to be higher than the driver side, that way you have the light aimed more at signs and things like that, or was that just for HIDs?
Old Mar 9, 2004 | 09:10 AM
ohannon7's Avatar
The driver headlight comes from the factory lower supposedly so it dosent blind other drivers (HID owners, take note). This drove me crazy though, so i lowered the passenger, and raised the driver to "meet in the middle".
Old Mar 9, 2004 | 09:23 AM
Brudaddy's Avatar
neither of those links worked for me. You can really adjust the fogs like this. I knew about the headlights, but not the fogs. I have just been doing it the old fashioned way....holding up as much as possible when screwing the entire housing of the fog back in. It works, pretty much, but it is hard and annoying.
How do you get to the adjustment for the fogs? Is it under the watershield for the engine underneath the fenders? Where?
Old Mar 9, 2004 | 09:45 AM
DAVE Sz's Avatar
Hooooooonda.....
It says about the fogs in the owners manual.
Old Mar 9, 2004 | 11:34 AM
Brudaddy's Avatar
Thanks.
You couldn't just post it really quickly?
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
knight_yyz
Nov 1, 2015 01:34 PM
trsandrew
Oct 25, 2015 02:47 PM
Noela
Sep 26, 2015 08:22 AM
