Auto Rx. Anygood? Engine seals?
Old Mar 8, 2004 | 11:21 AM
eturnl
Has anyone tried this stuff? (www.auto-rx.com) is it anygood? I have some engine leaks from near the top intake and exahust manifolds. they dont look like fresh leaks, more like old dried leaks, but im not sure.
I also have another leak, this one is bad. its all around the oil pan, its so bad i cant tell if its the filter, pan gasket, or the Oil pressure switch thats causing the leak. I think the bottom leak has gotten worse since i switched to synthetic about 3000 miles ago. anyway i can fix this one. (i just thought i'd mention it in case it was useful info).
Anyway I just want to know what this RX stuff can do. also their website mentioned engine seals being worn or bad, and how this stuff an fix it. im not sure what these seals are! Anyone?
Old Mar 8, 2004 | 11:24 AM
ABK's Avatar
ABK
try cleaning up the mess and see. The top is prolly the valve covers (give better discriptions), not hard to do. The bottom is most likely oil pressure switch, shouldn't be too hard. Don't put that stuff in my autotech teacher told me that this stuff will just make your seal expend and they will start leaking alot more over time.
Old Mar 8, 2004 | 12:11 PM
98SterlingMax's Avatar
Humble '06 TL Owner
Oil pressure switch leakage is a semi-common problem. Easy fix...
Old Mar 8, 2004 | 03:23 PM
eturnl
OK but what are the engine seals...
derekinthez
Nov 13, 2022 04:00 PM
Mar 12, 2020 12:06 AM
fastcarny
Oct 6, 2015 10:42 AM
The Wizard
24
Oct 1, 2015 08:47 PM
seesole
Sep 14, 2015 12:38 PM
