Air Bag light Blinking... Help
I had to unhook my air bag box underneath my arm rest when i replaced my carpet and now it wont stop blinking. i tried unhooking the batterey but it didnt work, do i hace to reset my ECU??? Thanks for any help guys.
airbag light
I just read this in the FAQ section. Goes something like this:
How to reset SRS(air bag) light –
Open the driver's door. Note the rubber covered button located low on the B pillar, a button which is pressed by the door when the door is closed. This is the Driver's Door Switch (DDS).
Turn the ignition from OFF to ON. Press the DDS at least 5 times within 7 seconds after turning the ignition switch ON. Turn the ignition OFF. Close the driver's door. Start the engine.
If the airbag warning lamp is still on (or still flashing), there is a fault in the Supplemental Restraint System which must be diagnosed and repaired. This is a job for your local friendly Nissan dealer.
I hope that works.
I hope that works.
i don't think u can reset ur air bag light throught the ECU, u would have to do it with the door button, what i was woundering....if u take out ur airbags would that light goo off?? and would they notice it on the inspection???
sdotcarter
Sep 2, 2015 09:53 PM
