MPG Ripping me apart. 220 'till light. I need HELP!
Old Mar 10, 2004 | 01:12 PM
JetBlack SE's Avatar
I keep asking the same question becuase every time I could never get aid. Here is the situation...
1995 Maxima SE w/ 122K miles.
1 Owner before me, Dealership serviced ONLY.
ECU shows 0505 meaning no problems detected
I get about 220 miles of 80% city driving untill the gas light comes on.
I spend $30 every dam week.
Please help!
Old Mar 10, 2004 | 01:35 PM
Brudaddy's Avatar
I don't know what to tell you. I just pulled the same code out of the ECU last night. I thought I might have at least needed to get a new knock sensor, but it does not say I need one.
However, I have heard that it will not cause the ECU to throw a code until the knock sensor is totally bad. I would probably just suggest getting one off of ebay or something and trying it out. Also, do things like replace the fuel filter(get one from the 350Z....it is bigger and supposedly works better.).
I am getting better gas mileage than that. My light doesn't come on until I reach like 360, but I am still debating on getting that knock sensor or not. I don't know?
What do you other guys think about his knock sensor? should he probably go ahead a get one, even though there is no code? I am voting yes, because it is a 95 and should be needing one right about now.
(fuel filter and plugs are easy and cheap, I would start there)
Old Mar 10, 2004 | 02:04 PM
thanks man, i appreciate the feedback. I will try to get the fuel filter and plugs this weekend.
Old Mar 10, 2004 | 02:15 PM
Maciek's Avatar
disconnect the sensor and see if you can tell the difference in the way car behaves. If not- it is faulty, change it.
How hard do you drive? Do your average shifts happen around 2500 rpm, 3000 or 4-5000?
Old Mar 10, 2004 | 02:17 PM
Brudaddy's Avatar
You ought to be able to get all 6 plugs (NGK coppers) for about $12, and a fuel filter (I got Bosche for I think like $10).
Just look for how to install them, but neither are too hard.
Good luck trying this out, and let us know what happens. Hopefully, this will cure what is ailing your car.
Oh, and No problem on the feedback. That is what we are all here for...to help out.
Old Mar 10, 2004 | 02:28 PM
disconnect the knock sensor?
and for the shifting...
its an auto and i got a heavy foot. i dont floor it at every light but i go about 40-45 in the city and sometimes show off the 190hp at those red lights at 3am
Old Mar 10, 2004 | 02:31 PM
i will check tonight or tomorrow about my shifts... but if i recall correctly its about 3k.
Old Mar 10, 2004 | 04:40 PM
I took her out for a spin.. and it shifts at 2.5k flawlessly. I mean i love this CAR! The ride is smooth as hell, if you gun it... it responds like it got a dam rocket engine and overall i couldnt be any happier.
Also i checked the tire pressure and it perfectly meets the manuals recomendation.
I don't think its the knock sensor and will get the fuel pump and plugs in a day or so...
Old Mar 10, 2004 | 04:42 PM
meanbean's Avatar
Check your tire pressure/wear, air & oil filters cause those can contribute to bad gas mileage. Also, try a bottle of Valvoline's Fuel System Cleaner the next time you have to fill up. I used it on mine and noted that it works wonders. Good Luck.
Old Mar 10, 2004 | 04:45 PM
Pasty's Avatar
I have the same problem, 130k miles, and i get 220 on a full tank. I'll be trying some of the said solutions and willl report back.
Old Mar 10, 2004 | 04:54 PM
Had oil change 1 week ago, air filter and oil filter changed.
Tire pressure is perfect as i mentioned above.
I have 2 diff fuel system cleaners ready for next fill up. (1 on empty tank and 1 on full)
Also have a can of RestoreUSA ready for use before fill up.
I will drive this tank on O/D OFF (light on). And will report my progress....
Also Pasty let me know if you come up with anything.
Old Mar 10, 2004 | 06:32 PM
fishpony's Avatar
why would you drive with the overdrive off? maybe thats why you got such bad gas mileage, fourth gear is there for a reason
Old Mar 10, 2004 | 06:51 PM
superblack98se's Avatar
I am getting around 290 with od on, I am due for an oil change though, and need new spark plugs.
Old Mar 10, 2004 | 06:54 PM
my99maxisnice's Avatar
what ****es me off, I get 270 for the first 3/4, 30 on the last quarter
Old Mar 10, 2004 | 08:25 PM
eckohb's Avatar
i also get about 200-220 mpg. I also tend to drive about 40 through the city, and occasionally open up the VQ when I think no one is looking. Im a little above 1/4 tank at 190 miles...I changed my plugs two weeks ago, changed oil and filter then too. The air filter only has 2k on it. Maybe a fuel filter change is needed. My EGR is throwin a code, does that affect gas mileagE?
Old Mar 10, 2004 | 09:32 PM
bng4bk's Avatar
220! Man, that makes me feel good, that's got to be sub-14 mpg. I think my 17 city sucks. I've done pretty much all that tune up crap with little or no results. I get an 0505 code, so my car thinks its fine, but what a pig. The low end pickup is a dog. I have to bury it to get anything resembling rapid acceleration.
A local tech said I would lose as much as 20% mpg due to the winter oxygenated fuel, but we've shifted over now and I don't see any change. I drove a bit of freeway and squeaked out 19...woohoo! The tech also said the maf could be reading wrong, but after replacing plugs, filters, adding intake, y pipe, etc., I'm tired of troubleshooting through replacement and a maf or coils aint cheap.
Anyone have any thoughts on the possibility of maf or coils giving retarded performance/ bad mpg with NO codes?
Old Mar 10, 2004 | 09:38 PM
happyricefob's Avatar
V^___^V
i get about 320 at 14 gallons, 380 at 16.5 gallons with 50/50 hwy and local driving. 23mi/gallon.
i'm running mobil 1 supersyn 5w/30, oem nissan filter, k&n recharger kit on the jwt filter, cleaned throttle and IAC valve, good condition NGK 1 step colder spark plugs, brand new knock sensor, good o2s, good engine coolant temperature sensor.
maintance > modding
Old Mar 10, 2004 | 09:41 PM
eckohb's Avatar
my rear o2 sensor is throwing a code, along with my EGR valve. I figured my o2 sensor would affect it, but i read before that if the front two are working, that the rear sensor wont affect gas mileage. im not sure about the egr valve. ill look into it this weekend though
i also have mobil 1 supersyn, just changed it about 1k ago. I'm gonna look into replacing the fuel filter this weekend. I agree with the maitenance > modding. It's just been so dam expensive to keep up with it. I've changed the knock sensor, the two front o2 sensors, flushed tranny, new brake job that still squeaks, and now its like i get a new code to replace the one i just fixed. but when she's finally running smooth like she should, ill be happy
Old Mar 10, 2004 | 10:47 PM
DAVE Sz's Avatar
Hooooooonda.....
What exactly does that have to do with anything? When he said what rpm it shifts, he was asking about your driving habbits. If it shifts at 2500rpm or below it means you don't drive hard which should make your fuel economy better.
Old Mar 11, 2004 | 09:10 AM
Brudaddy's Avatar
and you need fuel filter, not pump.
Old Mar 11, 2004 | 09:28 AM
Well i just fuled her today and added all those fuel cleaners i bought. I fuled to 15.6 gallons and had 210 miles on that tank. Thats when the light came on. Thats under 14 miles/ gallon!
I drove that tank with OD on (light off).
This one i will try with OD off (light on).
And when I was asked about the rpms i thought it was a relation to the milage, since my old car '92 legend, had an rpm problem with late shifts.
Anyway well c what happens...
Old Mar 11, 2004 | 09:31 AM
On that note, I think im gonna go take some pics.. and get a car domain page going...
Old Mar 11, 2004 | 10:47 AM
DAVE Sz's Avatar
Hooooooonda.....
O/D should be turned on when driving 40mph or higher only. It won't change your ga mileage at ALL if you drive with it on or off the whole time. Those fuel cleaners you bought, you just threw your money away.
Old Mar 11, 2004 | 02:11 PM
Thats not neccessarly true. I heard about, and seen the cleaners working, so I dunno where ur getting ur info from.
Old Mar 11, 2004 | 02:23 PM
Maxine's Avatar
I've always been too scared to go to the gas light.
about how miles can i get when the light comes on, and about where is the needle on the gauge when the lights comes on.
Old Mar 11, 2004 | 02:32 PM
eckohb's Avatar
you got about 2 gallons left when the light comes on
Old Mar 11, 2004 | 02:35 PM
Brudaddy's Avatar
correction.....1 gallon when the light comes on. I have run out of gas trying this! ha ha.
You have a little more maybe if the light first comes on and doesn't stay on, but when it stays on, you had better be pulling into a gas station, because according to most people's mpg, you have about 20 miles.
Old Mar 11, 2004 | 03:57 PM
Pasty's Avatar
I just got my new fuel filter, and what do you know, no instructions. how do i install this?
Old Mar 11, 2004 | 03:58 PM
Kolyan's Avatar
How do you disconect the sensor other then pulling the plug? is there a fuse for knock sensor?
Old Mar 11, 2004 | 04:06 PM
I had my light come on today, and this was wen i was in line for a car wash... well i got a little scared, but manged to get to the station...and it filled up 15.6 gallons! thats 3 gallons left.
Derrick2k2SE
Nov 19, 2015 10:14 PM
ef9
Oct 4, 2015 08:43 AM
worldwiderecognized
Sep 24, 2015 06:56 PM
220k+ A32
Sep 22, 2015 03:08 PM
