ECU code 05 05 help
Old Mar 12, 2004 | 07:39 PM
Allen's Avatar
ECU code 05 05 help
a week after replacing my knock sensor and resetting the ECU, the CEL came back on again today. At first i thought it might be the knock sensor woes, but when i checked the code it was 05 05: everything's ok. so then how come my the CEL came on again? i'm confused
Old Mar 15, 2004 | 04:53 PM
Allen's Avatar
^ anyone? .
Old Mar 15, 2004 | 05:01 PM
mzmtg's Avatar
Minister of Silly Walks
0505 is defined in the service manual as "replace engine immediately"
Old Mar 15, 2004 | 05:17 PM
max2max-98se's Avatar
In Maxima We Trust
you should be ok 0505 means you have no probs unless it come backs on again after you reset check it for other codes
Old Mar 15, 2004 | 07:21 PM
ManualMaxima's Avatar
5th Gen till she dies!
hahaha that code would suck...yea it means runnign good.
Old Mar 15, 2004 | 07:28 PM
happyricefob's Avatar
V^___^V
lol ben...you always do that to
Old Mar 15, 2004 | 07:35 PM
maxjetblack's Avatar
whoa~ i was scared there for a second...
yeah i had 0505 the other day too and my car is running fine.......still. hopefully no other problem comes up~
Old Mar 19, 2004 | 03:47 PM
Allen's Avatar
guys, i keep resetting the CEL and it keeps coming back on, but it's only the 05 05 code appearing. what gives??
Old Mar 19, 2004 | 03:56 PM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
Do you have a CEL on? Well, The code 05 05, is a code saying to you everything is fine. When they designed the ECU they put that code in the ECU to show that everything is fine. When something is wrong the code changes. For example if you have a bad knock sensor the code changes from 05 05 to 03 04. I don't know why you keep resetting the ECU? There is no need to reset the ECU if you have the code 05 05 and the check engine light its not on.
Old Mar 19, 2004 | 06:06 PM
Cool J's Avatar
0505 means everything is running fine. i just replaced my knock sensor and before it was 03 04 and now i get an 05 05 so the knock sensor did fix the problem
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
