Cat converter size
Old Mar 13, 2004 | 05:09 AM
thisasian's Avatar
Cat converter size
I have a y-pipe, but a modified custom b-pipe. Which size cat am I supposed to get? 2.5" or 2.25"? thanks
Old Mar 13, 2004 | 08:22 AM
budha56's Avatar
You probably want one to match the size of the rest of your exhaust. WSP and budget Y are 2.5, I heard stillen is 2.25. What's your B pipe? You wouldn't want to bottleneck a narrower cat than the rest of your exhaust, but it doesn't need to be bigger either.
Old Mar 13, 2004 | 08:27 AM
Torgus's Avatar
stock is 2.5 most Y's end in 2.5 i think...
Old Mar 13, 2004 | 06:58 PM
thisasian's Avatar
right... this is what I'm unsure about. Which end of the cat takes priority, pre or post cat. The y-pipe is 2.5", but the b-pipe is 2.25" (stock). The only thing I had done to the b-pipe was replace the resonator which was damaged. I had the guy weld new 2.25" tubing just far enough to eleminate the flattened section, which motorvate.ca talks about in the b-pipe review.
Since I just paid to have this resonator put in ($40), I don't want to redo the whole b-pipe just to "match" my exhaust system.
btw, I'm not sure if it was replacing the damaged resonator, or the squashed pipe section, but I know my car now has more bottom end power and is more responsive.
More suggestions and knowledge are appreciated.
Old Mar 13, 2004 | 07:46 PM
Torgus's Avatar
all i know is i have a 2.5 b pipe and it mounted to the stock cat with no problems.
Old Mar 13, 2004 | 08:21 PM
thisasian's Avatar
is your b-pipe stock? or stock diameter? b/c I might be wrong in thinking that stock dia. is 2.25"
Old Mar 13, 2004 | 08:32 PM
Torgus's Avatar
mine is aftermarket.
Old Mar 14, 2004 | 06:38 AM
thisasian's Avatar
bump... lookin for people w/aftermarket cat and stock (or stock diameter) b-pipe
Miket2006
Mar 1, 2021 03:55 AM
maxinout93
Oct 31, 2015 02:04 AM
09maxshawn11
Sep 30, 2015 10:28 AM
sliptap
Sep 30, 2015 05:57 AM
