help! check engine light on
Old Mar 14, 2004 | 02:24 PM
maxjetblack's Avatar
i changed the gauge bulbs last nite and i dunno if i touched anything but the check engine light came on today. It doesnt seem like there is anything wrong with the car but it's buggin me alot. does anyone know how to get rid of it? did i set something off when i changed the gauge bulbs? any help would be appreciated...thanks~
Old Mar 14, 2004 | 02:37 PM
happyricefob's Avatar
V^___^V
ugh...changing the gauge bulb shouldn't trigger the CEL. it must be something else internally broken (i'm pretty sure)
please read all the FAQs in the 4th gen forum sticky, and here's how you pull and determine your CEL >> http://forums.maxima.org/showthread.php?t=104931
Old Mar 14, 2004 | 02:55 PM
tcf_dk's Avatar
YOu can always do a diagnostic check if you got the code book.Then you can get a little closer to solving your problem.And if you didn't see or hear a spark,you didn't do nothing wrong.
Old Mar 14, 2004 | 04:14 PM
i tried the self diagnosis thing and first found two problems. But when i reset it and did it the second time, the check engine light blinked 0505 which means no problems detected and now my check engine light is off when i start my car. I was just wondering, does anyone know if the problem is gone? or should still get the problems checked out? thanks~
Old Mar 14, 2004 | 04:47 PM
max2max-98se's Avatar
In Maxima We Trust
if the check engine light was 0505 and it disappeared it should be fine.if it comes back on again you might want to check it for other codes
Old Mar 15, 2004 | 05:54 AM
thank you~
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
Flores94
Aug 11, 2015 12:53 PM
