Manual Tranny HELP!!!
How in the hell do you check the fluid in the 5-speed tranny on a 97 nissan maxima I think I might have tranny probs, I get a bad grinding when in gear only on right turns and straight not on left turns, anyone please help me
I would suspect a bad left or right CV joint. But to check the tranny level, jack up the car perfectly level and then unscrew the upper drain plug(for lack of a better word) It should either slightly drain out or if you stick your finger in there, it should be just below the drain opening hole.
Just in case...
Hope you didn,t do what I did....
well I just put in my springs and the cv boots looked fine is it possible they are bad and not have cracks or anything?
Really no way to check your manual tranny fluid levels as Nissan intends it to stay put for the life of the vehicle. I put in Redline MT-L and notie a huge diff...
But unless you see leakage, your fluid is ok. The other members opinions about your cv, etc... sound on point.
take it to the man..
Re: Upper drain plug = fill plug
Oh yeah. I forgot because I don't use that plug to fill the tranny anymore. It's too much of a pain. I just undo the speed sensor and use a long hose w/ a funnel. WAY faster and WAY easier. Espeically when you pre-measure the amount first.
Originally posted by Daniel B. Martin
It is called the Fill Plug.
tarun900
19
Dec 20, 2021 06:57 PM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
