Auto shifter to high
Is the any wayto make the auto shifter smaller.
Here ie a pic of my supra auto shifter. Can I make my Shifter that small?
http://cgi.ebay.com/ebaymotors/ws/eB...&category=6447
Look a the bottom of the page.....
someone on the org. done a fake 5spd sway, aka adding leather boot and a 5spd shift **** over his automatic shift ****. it looked shorten too.
too bad he doesn't have the OD button anymore. and that's ultimate ricer right there
Well I like to fish. The bigger the better.
This sucks that I can not search because I saw a post about this like a mouth or so ago.It would be a big help if someone that can search try to find it for me.
Originally Posted by CiViC KiLLeR
As soon as my turbo kit is at my front door I will not be scared of anyone.
Originally Posted by Nismo
theres always a bigger fish
The shifter's not to high, the console is low. I believe the center console on the Supra is "higher" on your seated body. It's just been my experience, and if you think about it probably yours, that the top of a gear shift is at a height where if you arm is on the armrest or at an approx. right angle your hand rests right on top of the shifter. I belive this is where using the shifter is most comfortable for the masses. You can shorten your shifter for looks. It will just feel a little different to shift it.
Originally Posted by zazon
too bad replacement auto shifters are far and few between, the only one i have found is f'ugly. its that chrome/carbon alien looking thing, anyone know what im talkin about?
There are a few I've seen.
The Razo (I believe the one you're talking about)
brown wood grain
http://216.82.69.117/detail.asp?PRODUCT_ID=RA-106
black/gray wood grain
http://216.82.69.117/detail.asp?PRODUCT_ID=RA-105
the Levoc
http://www.importscene.com.au/prod522.htm
and the one on custom maxima (which looks like a chrome Razo,maybe? not sure what brand it is)
http://www.custommaxima.com/Shifter.php
Originally Posted by RideTheMax
I like the 2000 dodge intrepid auto shifter, sits nice and low. lower than a sts for manual. it's sweet.
I don't think an auto shifter that low would really look right on a max though. On a 300M/Intrepid, it kinda flows with the rest of the interior, but a max's dash is way too angular (DIN's, climate control, etc) compared to the Dodge for that.
the only time I saw that done, the guy used an aftermarket shifter so he kept the OD.. looked pretty good I thought, working on it now
.. no rice
I just do not like how high it is.If I could cut maybe 1 inch or a little less off I would be happy. Does anyone know how to do this or is there any write ups about this.
I do like the adding a leather boot thing but it my look a LITTLE to ricey
Levoc Auto Shift ****
It isn't too hard to install the aftermarket shifter. If you try to use the stock holes with the aftermarket shifter you'd have a really ugly tall beast, like a truck shifter or something. I hacked off about 1.5" from the metal pipe inside the stock shifter, drilled a new 1/8" hole inside that pipe, shortened the inside spring release rod (don't know if you guys know what im talkin about- its is the thin piece of metal seen in the pic below), and now the shifter is sitting a lower than the oem or an aftermarket that isn't sawed.
I went to Kragen and borrowed their pipe cutter for free, and although it was too big, I just took my time and made a lot of small cuts until it finally fell off. The metal rod inside was pretty easily cut with a wirecutter.
I'd imagine it would be possible to shorten the stock shifter, but you will have to hack it on the bottom, and find a way to re-solder the od switch wires and reattach them. You could probably cut down like 2-3"... I'd pick up that spare stock shifter and play around with it and find out.
P.S. I don't recommend the Levoc, the chrome part on mine is chipping off. I've had it about 3+ years.
I dunno, 20 shipped? its the whole lever assembly- shift stick thing with that button thing on top and the lever pivot thing. let me know and Ill dig it up from the garage and take a pic or something if u want to see
Here's a side shot if anyone is interested in that angle.
I do not want to keep my stock auto shifter I would like to get a aftermarket one Nismo but how much do you want for it.MaximaGTR34 thanks for the write up that helped alot.
AaronL
Aug 8, 2020 10:31 AM
Maximeltman
Sep 28, 2015 07:19 PM
atriuum
Sep 28, 2015 01:19 PM
