Cooling Fans will not turn on
Old Mar 20, 2004 | 04:21 AM
dhawthrone's Avatar
98 SE, thermostat defective, had it replaced, but now the cooling fans will not turn on. If i manually spin the fans while the car is running, it will eventually start to run on its own, its like it wants to run but can't. Maybe the fans need replacing?
Thanks In Advance
Old Mar 20, 2004 | 05:54 AM
mzmtg's Avatar
Minister of Silly Walks
Does the car overheat if you just let it idle for long enough?
The fans should come on when you turn on the AC compressor, do they?
Old Mar 20, 2004 | 08:24 AM
Magikone69's Avatar
i have that problem too, the fans never turn on, not even with the AC on
Old Mar 20, 2004 | 09:53 AM
dhawthrone's Avatar
Initially the fans would not turn on at all, even with AC on. But it would not overheat, the temp gauge stays in the middle. I replaced the relays for #1 and #2 and it started working ( I think). Standing in front of the car, the fan on the left comes on when the AC is turned on now. Is the one on the right supposed work as well? Does anyone know what relay #3 does?
Old Mar 20, 2004 | 03:36 PM
Str8ballin's Avatar
Relay 3 is for the high speed setting. Comes on if the car gets up to 221 degrees. The fan (s) run faster for better cooling. I would hook the fan motors up directly to a 12volt source and see if they come on if not the motor is bad.
Smackasmith
Feb 1, 2016 12:40 AM
LtLeary
Sep 14, 2015 12:33 PM
asianstyle
Sep 10, 2015 11:30 AM
