No Radio, Clock, or Keyless.. Help Please
Old Mar 16, 2004 | 08:19 AM
95GreekMaxSE's Avatar
I have the stock radio hooked up to an amp, I turned the radio up too loud and it turned off along with the clock, and there is no keyless entry. I have to lock my doors with the key. The lights on the radio go on when the lights are on. I checked the fuses, is there a specicfic fuse for this, any help is really appreciated.
Old Mar 16, 2004 | 08:43 AM
geo1317's Avatar
Check the fuses again, it should be one of the fuses in the panel under the dash.
Old Mar 16, 2004 | 08:50 AM
Maxine's Avatar
Yeah same problem happened to me. Check every single fuse under the kick plate even if you dont think it may be it or related to the radio.
Old Mar 16, 2004 | 08:56 AM
Do you remeber which fuse it was for you??
Old Mar 16, 2004 | 08:59 AM
Do you remember which fuse(s) it was for you??
Old Mar 16, 2004 | 09:01 AM
geo1317's Avatar
ill go and look at it later today, i remember it was not an obvious fuse.
Old Mar 16, 2004 | 09:03 AM
meanbean's Avatar
Try replacing the BCM fuse under your hood. It's located in the fuse box right above your battery.
Old Mar 16, 2004 | 09:06 AM
you guys are really great, i will try this when i get home from work, Thank Again
Old Mar 16, 2004 | 09:25 AM
Teameyekon's Avatar
If all of those things went out it is definitley one of the fuses located by your battery...I forget the name of it, but there is one fuse that runs all of that stuff...I popped it once or twice while installing my TV and HU
Old Mar 16, 2004 | 09:58 AM
Sped's Avatar
hmmm. I have no radio but the lights for it turn on as well. yet my clock and keyless entry still work. ill have to look for this fuse myself too.
gavin68
Sep 18, 2021 12:36 PM
chisam14
Nov 6, 2018 08:56 PM
t6378tp
Sep 29, 2018 04:27 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
