torque wrench absolutely necessary - FSTB?
Originally Posted by formz
No for a strut bar install you don't need a torque wrench. Just get them really tight. If you're building a motor or doing something major, then yes you do need one.
Originally Posted by my99maxisnice
I guess I'll head down to home depot...there's no special kind of torque wrench is there?
they are torqued 80ft/lb on my 17s voxx MGRs.
you can always do like I did. Just go to a AutoZone (pepboys...) and ask if you could use their torque wrench, (with all the nessessary extentions, sockets). and do it right in front of their store.
It took me 15 minutes to do the job (they even set the torque to the correct degree for me). all I had to do was unbolt, put the bar, and bolt until I hear the click.
You won't spend any money.
If you know some one that works at the autostore, makes it easier to borrow. (lend it to you).
hope you understand what I said.
The instructions warn in capital letters not to overtighten...also, about how much do they go for?
Torque wrenches are good if you really want to be **** about it, but I never am, and never have a problem. Just use your head.
Another question...the write up says the strut bolts are 19mm...Mine are much bigger than that...can anyone with a 99 clarify?
I put mine on w/ out a tourque wrench, i cant remeber how big the bolts are, go out there, find the socket that fits on it and thats how big it is. I ended up using a BIG a$$ wrench, b/c mine were on too tight
The thing is, mine are huge...a 21 mm wouldn't even fit over it...so I quit to go play madden
You guys who lay into the b!tches are retarded. They are meant to be just over 30Ib/ft. For comparison 10-13Ib/ft is hand tight and you can lay down about 500Ib/Ft with a 9" socket wrench. If you go to tight the flex in the suspension geometry and chasic is completely eliminated which is great until the bolt snaps and then you need a new upper spring mount thing.
broaner22: Uhm...in order to do 500lb/ft with a 9" socket wrench, you'd need to put 666 2/3 lbs of pressure on the wrench. You must be a big dude!
my99maxisnice: I'd just go get one from Sears (Not the digital kind, but the one with the lifetime warranty). $20 and you're guarenteed to get those bolts just right. If you're only buying one of them, I'd get one that goes up to ~150lb/ft.
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
RWCreative
Sep 21, 2015 11:01 AM
Hdnseek
Sep 9, 2015 05:55 AM
