Clutch!
Old Mar 19, 2004 | 05:20 PM
lxl - MaX's Avatar
Clutch!
a friend said that I need to replace my clutch.
can i just bleed my clutch or do any thing instead of buying a
new one
Cause im poor
its an exedy stage 1 clutch
Old Mar 19, 2004 | 07:22 PM
lxl - MaX's Avatar
Help ME
Old Mar 19, 2004 | 08:19 PM
car_boy_16's Avatar
You dont have any emergency funds??! Not smart...
Im new to Maximas so I dunno if there is an adjustment for the clutch (my Prelude has none). You could buy a clutch disc and resurface the flywheel and maybe the pressureplate if the machinist/mechanic says its safe to do.
Old Mar 19, 2004 | 08:43 PM
vortechpower's Avatar
how many miles do you have on you clutch? if its letting out real high it can be adjusted closer to the floor, if its not worn out. how to do that im not sure , had a friend do it for me.
Old Mar 19, 2004 | 08:46 PM
liqidvenom's Avatar
brotherhood of tq
emergency funds? any money lying around should be spent on mods.. not waiting around until the car breaks. I read somewhere that if you want to check ur clutch then u could let the car get cold from sitting like overnight, then leave it into neutral then try and go from 1st to reverse. if u could do that then ur clutch set up is fine
Old Mar 19, 2004 | 08:50 PM
sryth's Avatar
new one
What makes you think it's slipping? How did you test it?
If your clutch is slipping, you will most likely need a new one. The clutch system (IIRC) adjusts itself as the disk wears down, so adjusting further is not a good idea.
How many miles are on the clutch? If it's low enough miles, you might be able to just replace the disk.
I wouldn't say this is conclusive at all.
The best way to test is to get out on the road; cruise in 5th at around ~2krpm and floor the gas. Keep an eye on the tachometer; if it moves independent of the speedometer, your clutch is slipping.
Clutches begin to slip in higher gears first, but if it's slipping at all, I'd start saving for a replacement.
Old Mar 19, 2004 | 11:58 PM
lxl - MaX's Avatar
i bought my car off ebay and the guy said that he recently changed it. but idk, whenev i shift the rp,s will stay very hgh and it feels like its not in gear... after a sencd or two, it will "catch".
any ideas?
Old Mar 20, 2004 | 12:40 AM
ManualMaxima's Avatar
5th Gen till she dies!
yea it is gone prob....do this.....go about 50 down a road. and while doing 50 in 5th gear, floor it. if you rpm's raise but the car does nothing untill it has to "catch". then it is wearing out, and you better get it fixed before you will have to tow it to a shop an dcost even more money.
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
spencerwh1
Jun 30, 2016 05:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
