HELP!! CLUTCH is leaking fluid
here is the pic that my clutch is leaking fluid
http://www.angelfire.com/music5/shortyyanny/dammmm.jpg
The pushrod is the little **** that presses against the clutch-lever. It has a rubber acordian style boot around it.
Well, I can't see to well in the picture, but if it's not the hose, then it's most likely the piston seal.
If it ends up being the piston seal, you will either need to replace it or rebuild the slave cylinder.
Originally Posted by skiboarder72
I have a leak too but i don't know where its coming from, the tank just drains down
Mar 12, 2020 12:06 AM
fastcarny
Oct 12, 2015 07:06 AM
pears
Sep 18, 2015 05:25 AM
