Rattle From Broken Gasket?
Old Mar 21, 2004 | 05:32 AM
96white's Avatar
I have took a look at my whole exhaust system last week because ive been getting a rattle at low rpms, when i rev, and when i change gears. It looks like Not the front pipe down from the y pipe but the second one, that the gasket was blown, and all my bolts were loose ?? Would the broken gasket have fallen into the y pipe and be caught at the CAT? I def. hear all the noise coming from the CAT ? Any help would be great !!!
thanks guys
Old Mar 21, 2004 | 05:35 AM
happyricefob's Avatar
V^___^V
get new exhaust gasket, tighten the bolts, add exhaust wrap, remove heat shield to see if it fixes the problem....
Old Mar 21, 2004 | 05:38 AM
96white's Avatar
wouldn't i need to get piece/pieces out of the exhaust first? Second, where do you get exhaust wrap, and what is the function of it?
thanks
Old Mar 21, 2004 | 06:18 AM
nismos14's Avatar
§è~® f®ÈÄk
thanks guys
the gasket probably shouldnt fall into the y and stick in the cat, BUT the possiblity is there. I would suggest gettign new bolts, new gasket, and removing the entire y - pipe to the cat, inspect the inside of the cat, and inspect the inside of the y pipe. once you're sure that nothings stuck inside, replace the the parts and re-install, you don't need header/exhaust wrap, the heat shield is probably not the problem since you already noticed the broken gasket and loose bolts.
If you really want some header wrap i have some for sale, just pm me
check out my thread http://forums.maxima.org/showthread.php?t=281182
i still dont see the sense in getting it tho, so first try all the other steps
and see where that gets you good luck
any questions, just pm me.
Old Mar 21, 2004 | 06:28 AM
96white's Avatar
Thank you !
Old Mar 21, 2004 | 06:36 AM
nismos14's Avatar
§è~® f®ÈÄk
no problem, keep us posted
litch
123
Jan 4, 2024 07:01 PM
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
knight_yyz
Nov 1, 2015 01:34 PM
