Drop Res Mod = CEL ???
Old Mar 21, 2004 | 11:56 PM
DaBombX's Avatar
I was planning on doing the Drop Res Mod on my auto.
In fact everything is set to go.
I got the switch, and I made a custom bracket out of a wire hanger.
I even got it all installed in the engine bay with wiring all layed out.
All i gotta do splice and connect.
The only thing that's holding me back it that I've read about CEL when disengaging the dropping resistor.
Is this true?
Will the CEL come on everytime the car shifts while the the resistor is disengaged?
or does it go away?
The problem is that I go WOT almost every chance I get...
Since the switch is activated at WOT, it would be a pain in the neck if the CEL came on everytime I went WOT.
I'm Just too lazy to clear the codes everyday cuz I wouldn't be able to drive the car if the CEL was on. (CEL freaks me out...)
Anyway.
Can anyone clarify the questions above?
(Jime, you there?)
Old Mar 22, 2004 | 12:17 AM
Sentinal's Avatar
Is this true?
or does it go away?
Anyway.
(Jime, you there?)
Yes, its true the CEL does come on, all you have to do is reset the ecu. I just did this mod with an on/off switch in the cabin. But after like 2-3 runs with it disengaged the light comes on, just reset the ecu.
Old Mar 22, 2004 | 12:18 AM
Jime's Avatar
No it doesn't come on every time and it usually resets itself so its not really a problem.
Mind you I only go WOT usually at the track so I don't have a lot of experience with it.
Also are you sure you have a N/C (normally closed) switch? Otherwise it ain't gonna work. Unless of course you use a relay to reverse it, I think Baggs did that.
Actually now that I think about it, its a trans ecu light which in not the cel, its the hi-beam or something like that at the top of the speedo that flashes when faulting the drop resistor.
Old Mar 22, 2004 | 12:20 AM
DaBombX's Avatar
Yeah, I got a nc/no switch like yours, except mines rated at 5A. Will that be okay?
Old Mar 22, 2004 | 12:22 AM
Jime's Avatar
Ya should be fine.
I edited my last post reread it. Its not the CEL that comes on for the DR, and it resets itself.
jmlee44
Oct 2, 2022 02:13 PM
jonreidhead
Jan 6, 2016 09:38 AM
maxima-junky
Oct 7, 2015 06:13 PM
Redfox
Sep 28, 2015 10:41 AM
