Are these brake instruction we use WRONG?
http://www.motorvate.ca/mvp.php/302
this says to push the caliper piston back into the bore (and be sure to drain the fluid out of the master cylinder)
the bendix web site says not to do that (but to open the bleeded screw) as pushing the fluid back into the Master cyl can screw up the abs system by pushing dirt into it.
whats right
sounds like the motorvate inst need a note or two added
whats right
whats right
whats right
I hope that answered your question....
That sounds like a very careful (perhaps correct) way of doing it... there maybe a possibility of messing up the ABS system... If you don't mind bleeding the system, that would be the BEST way of doing it.
I done the simplified way on non-ABS cars without any problems.
i donno why u are working with the brake lines...
if you are changing rotors, u don't need to remove the brake lines
if you are changing you brake pads, u don't need to remove your brake lines
if you are spray and pray ur brake caliper, u don't need to remove your brake lines
however...
if you are changing to SS brake lines, or draining your brake fluid, follow this direction >> http://www.greghome.com/Greg's%20Gar...edBleeders.htm
however...
bigfrank
Oct 1, 2015 12:51 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
