Bosch spark plugs
some member have reported hesitetion problems using Bosh +4 plugs. If you don't notice any problems then you might be a lucky one. If I were you I would replace them with NGK's
I don't know of any dyno proof but I have this proof: My wife used to have a '96 SE (totally stock). I have a '96 GXE with (at the time) y-pipe, full exhaust, PR CAI. Both automatics. After changing my plugs over to +4's, we raced and she walked me up to about 80-90 when we let off. I got on here, asked around, and changed to NGK platinums. We raced again and I walked away from her right from green.
It's taken a long time for me to live that down with her. May not be enough proof for some but it convinced me.
I also put in the +4's I had a slight hesitation but I had that with the original plugs. The hesitation went away when I added a pop intake filter, wondering the plugs needed a richer air/fuel mix, now wondering if performance would get even better with NGK's?
would that hesitation that your talking about be something like a "lag"
I know when i push the gas on my auto, ESPECIALLY in O/D ON that it doesnt exelerate smoothly, its more like i have to push the pedal farther and farther untill it either jerks and pulls, or it GRADUALLY speed up, not very fluid.....but i noticed that it is not so bad when O/D is OFF...
Is this just a characteristic of our cars at least on the auto? or do you think i might need new plugs? cause i have taken it to the stealer for the 100k mile check up, and they said my plugs are fine...should i go ahead and swap em out?
Or is this a different problem?
I would realy like some help on this, my car has been doin this for a while...i dont know if its normal..
So here's my opinion of what the acceleration pattern of the automatic transmission seems to be (regardless of whether O/D is on or off):
1st gear - slow
2nd gear - noticably faster
3rd gear - now we're talking
4th gear - saves gas
That sound right to all you automatic drivers?
magiconthetire
Oct 26, 2015 09:03 PM
Need help
23
Oct 2, 2015 08:56 AM
