Knock with 91 octane?
Old Mar 27, 2004 | 08:15 PM
DaBombX's Avatar
I was thinking and it seems to me that if you have a bad knock sensor, it wouldn't matter if you used higher octane fuel, right?
Cuz when the ecu determines your ks has failed, it's not going to be aggressive with the fuel air combo.
I think I've had a bad ks since I got the car at 121k.
So all this time I've been using 91 octane, I really wouldn't have noticed any difference.
I've ordered a new knock sensor.
But not I'm wondering, will 91 give me knock too?
Old Mar 27, 2004 | 09:08 PM
s0ber's Avatar
I dont think 91 will give you knock, whats wrong you dont have 92/93/94 in your area? :P nothing but 93 for me, in this heat I need 93 to keep it from knocking...
<-- miami =\
Old Mar 27, 2004 | 09:23 PM
happyricefob's Avatar
V^___^V
http://forums.maxima.org/showpost.ph...3&postcount=42
Old Mar 27, 2004 | 10:09 PM
DAVE Sz's Avatar
Hooooooonda.....
If you use 100octane you'll still have knock, just very, very little.
Old Mar 27, 2004 | 10:35 PM
DaBombX's Avatar
Having knock won't neccessarily make the ks go bad, right?
Old Mar 27, 2004 | 10:49 PM
DAVE Sz's Avatar
Hooooooonda.....
It shouldn't since the KS "lives" to hear knock.
Old Mar 27, 2004 | 11:58 PM
flashover's Avatar
In Nebraska, 91 is the best you can find. Without paying $3/gal for 141...
Old Mar 28, 2004 | 04:36 AM
Ceasars Chariot's Avatar
Old Maxima Legend
what codes come up if the knock sensor is bad ? it seems like i read that its not always a knock sensor code ???
Old Mar 28, 2004 | 06:48 AM
s0ber's Avatar
0304 :P
Its not always bad if it comes out with another code, I hear the knock sensor triggers a ghost CEL when you put really bad cheap octane in it or something im not sure if thats true or not...
Other codes can trigger the KS code but if you get it alone you probably have a failing/failed knock sensor...
Anyways, I also heard if you recieve very hard knocking that will drain some of the life of the KS and fail prematurely... Also this is something I hard on the org so nobody flame me for none of it, just relaying information previously passed on :P
DC_Juggernaut
Sep 28, 2015 04:07 PM
JoshG
51
Sep 21, 2015 10:41 PM
ac max 92
Sep 17, 2015 07:35 AM
