Blue smoke coming out of the exhuast?
Old Mar 28, 2004 | 05:26 PM
Zipp028's Avatar
I have blue smoke coming out of my exhuast and the engine is pinging... 93 octane is being used... i was wondering what the problem was... anyone know?
Old Mar 28, 2004 | 05:42 PM
Prophecy1's Avatar
Used to be it was a sign of burning OIL. Dont know for sure now.
Proph
Old Mar 28, 2004 | 05:47 PM
Wmaxima's Avatar
blue smoke = oil is slipping past your piston rings and burning up in the chambers with the fuel
Old Mar 28, 2004 | 06:01 PM
Nismo's Avatar
blow-by .
Old Mar 28, 2004 | 06:06 PM
Maximus101's Avatar
You are deffinity burning oil... Do a compression check on each cylinder to see if your within spec's.
If your compression turns out to be ok. Then it is probably a bad spark plug tube seal on the underside of your valve cover. These are round rubber gaskets. If these are bad then you could probably be leaking oil through where the spark plugs tread in. Thus fouling your spark plugs & causing your vehicle to ping.........
Old Mar 28, 2004 | 06:18 PM
maxdout00's Avatar
pinging + blue smoke = oil burning
my 96 was blowin blue also;and it was a spark plug seal letting oil pass it
Old Mar 28, 2004 | 06:45 PM
Str8ballin's Avatar
How many miles does it have? 141k here and no smoke at all
Old Mar 28, 2004 | 06:47 PM
LudeAEM's Avatar
as others have said... blue smoke = oil
Old Mar 28, 2004 | 07:00 PM
mansurxk's Avatar
while were ont he same topic, im wondering if that Alemite CD-2 actually helps slow down or prevent the blow-by, ive read stuff bout it on the net, but no concrete evidence ( i havnet searched vigorously)
Old Mar 28, 2004 | 07:37 PM
LudeAEM's Avatar
Well it may... the thing with those additives is that they add viscousity.... or "thickness" to your oil. So if a small amount of oil is by passing your rings or whatever... it may prevent that. Or thats the idea at least
Old Mar 29, 2004 | 07:40 AM
Zipp028's Avatar
well, i thank you all for the information!!
minsbang
Sep 11, 2015 08:48 PM
lux97Max
Sep 4, 2015 05:42 PM
TheMafia
Sep 4, 2015 08:26 AM
Wareagle92
Sep 3, 2015 07:18 PM
