fuel pump and regulator short question??
Old Mar 30, 2004 | 02:05 PM
Danny95's Avatar
what fuel pump walbro model should i get and what type of fuel regulator also...
Old Mar 30, 2004 | 02:06 PM
NmexMAX's Avatar
dot dot dot ...
Are you FI ? If you're not then it's useless, but if you are, sorry to invade your post, because I'm not FI, so I can't help ya
Old Mar 31, 2004 | 04:44 PM
Maximus101's Avatar
What mod's do you have done to your car? Unless your supercharged, turbocharged or using some super huge shot of Nitrous then I don't think you need to upgrade your fuel system? List you mod's & you might get others to give you good suggestions?
Old Mar 31, 2004 | 04:45 PM
Maximus101's Avatar
NmexMAN............
Why would it be useless to upgrade your fuel system unless your fuel injected?
Don't you think it would be better to have a electronic fuel pump instead of a mechanical fuel pump even if you vehicle is carburated instead of fuel injected? I've replaced too many mechanical fuel pump's in my life time because the diaphams took a $hit to say that there better then an electric fuel pump. Plus if you ever run out of fuel once you put more fuel in the tank & turn the key on your electronic fuel pump will pressurize the fuel line. I'm pretty sure that a mechanical pump doesn't do that?
Maybe you can give me some insight on why a mechanical pump is better then an electric fuel pump?
Thanks!!!!!!!!
BkGreen97
Apr 2, 2016 05:47 AM
rnb754
Sep 14, 2015 11:39 PM
aminus21
Sep 12, 2015 04:53 PM
