97 Maxima Start Question...
Old Mar 31, 2004 | 08:02 AM
ParaMax's Avatar
I didn't see anything in the FAQs or other stickies so I'll ask here.
I have a 97GLE .... Some mornings, the thing doesn't want to start right away. It's usually when it's cold... wet... or cold and wet... It's fine in the summer. But yeah, I'll start it, it'll start for like a second, then the revs will drop quickly and the car will stall out. Sometimes the car will catch itself, sometimes it won't. Usually, If I'm fast enough, I'll start the car, and before the revs drop, I'll punch the gas to keep the revs up. It'll always start like this.
After it's started, the car drives perfectly fine.....
Anyone else experience this? Any ideas?
Old Mar 31, 2004 | 08:07 AM
(_8*(l)Homer's Avatar
Hold the key in the on position until the beeps stop. This will allow time for the fule line to pressurize. You can hear the relay for the fuel pump turn off before the beeps stop, the beeps are easier to hear though. Sounds kinda strange, but it works. Or maybe try cleaning your throttle body.
Old Mar 31, 2004 | 09:12 AM
AntLis97's Avatar
i had the same problem.and still have it some times i turn the key and nothing happens . i took it to a shop they said it was a starter so i changeed it and a month later same thing happened . so if doesnt work i just move the shifter back and forth so i think it could be some think wrong with the conection. by the way its also a 97 gle so i guess its im not alone with this problem.
Old Mar 31, 2004 | 09:42 AM
njmaxseltd's Avatar
Clean your throttle body. Goto www.motorvate.ca for instructions. If your still having hard starts in the mornings, change your engine coolant temp sensor.
kjlouis
Nov 24, 2018 06:09 AM
02PearlSE
Oct 7, 2015 02:12 AM
acw
Aug 13, 2015 12:50 AM
halfpol
Aug 5, 2015 08:24 PM
Jcof88
Aug 3, 2015 10:43 PM
