ecu code help...
ecu code help...
well I got my codes and diagnosis
0708-Downstream O2 sensor circuit slow response fault
0313-Downstream O2 sensor maximum voltage monitor fault
now that I have these codes I am still stuck, the motor has more than 2 O2 sensors so I can't just go and replace them. Does anyone have an idea of where I should go from here without taking it to a shop? I turned off my CES light but it was back on after a couple miles. The car seems to run just fine. Any help would be appreciated...thanks
I would replace the downstream o2 sensor, its like 50 bucks from www.buyoxygensensors.com ... hows your gas milage? Replace that one sensor and i bet you will be fine....
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
