cornerlamp disassembly
Old Apr 1, 2004 | 08:50 PM
MrDicks95SE's Avatar
Offset Is Everything.
how hard is it to take apart the cornerlamp? you know.. the one next to the headlight. is it the same process as taking apart the headlights? specifically i want to take off the lens so i can "ae" it so it matches my headlights.
thanks.
richard.
Old Apr 1, 2004 | 09:00 PM
maxima98vspec's Avatar
i did mine....not hard at all.........preaty much the same procces as the headlights, just stick them in the owen for like 20 min at 200 f and u be alright.....
Old Apr 1, 2004 | 09:02 PM
BadFish's Avatar
Just heat it up evenly and it will come apart like anything else. Make sure you heat it evenly as possible or itll melt areas of the plastic and the rubber lining material. Believe me cause i used a heatgun to take them apart and the rubber outside stuff looks a little scorched and a couple edges look melted. Use a putty knife rather than a flat screwdriver cause you most likely end up cracking the thing; believe me i know about cracking the lens too. I painted it all flat black inside and it looks hella tight with amber bulbs.
Im really just saving for my smoked cefiro lights now. Good luck though and take your time.
Old Apr 1, 2004 | 09:06 PM
hah i hear you on cracking it with the flathead. i was just following directions but it was just minor chips. thanks for the replies.
KabirUTA13
19
Oct 17, 2015 02:15 AM
nadir_s
Oct 5, 2002 12:06 AM
Deac
Jul 19, 2002 01:29 PM
Maximan14
Dec 9, 2001 09:22 PM
jargoone
Jul 26, 2001 12:50 PM
