sprak plug wires and fuel filters ?
Old Apr 1, 2004 | 09:14 PM
Daniel's Avatar
okay i wanna do a complete tune up wit wires and and a filter and plugs what do u all recommend ?
Old Apr 1, 2004 | 09:23 PM
Gibby's Avatar
Plugs: NGK platinums (good for 60,000 miles, about $9-12 ea.) or NGK copper (about 30,000 miles and much cheaper)
Fuel filter: Most people recommend getting this filter from Nissan. I got mine at my stealership for $15. Some say you can buy the one for the Z and it'll last longer, but there's no performance gain.
I definitely recomment staying with NGK plugs. The plats are OEM, and I just put these in to replace some Bosch plats from the previous owner. It made quite a difference. Others have said the same thing.
Old Apr 1, 2004 | 09:33 PM
mansurxk's Avatar
NGK coppers, itll run you cheaper same performance just more frequency between changes 30k for copper 60k for platinums, as per wires, there are no wires, its a distributor less system in our cars, so you need not worry about that, coppers need to be gapped i think its .43 mm, im not absolutely surea but that though.
as for fuel filter, no clue, i used one from autozone since stealership wasnt open and i felt i had to change it, whiel your at it get some throttle body cleaner and check the how to's on how to clean that and the IAC, i did that the in combination with my fuel filter and my idle is not as jumpy (jumped like 50 rpms up and down while idling)
Old Apr 1, 2004 | 10:14 PM
guido32's Avatar
gap for plugs is .44mm; and usually if you get ngk's that a specific for the maxima they will usually come pregapped to this spec. Ex plug: BKR5E-11 (copper plug)
Old Apr 1, 2004 | 10:17 PM
Nismo's Avatar
you dont have wires
Old Apr 1, 2004 | 11:05 PM
DAVE Sz's Avatar
Hooooooonda.....
We don't have wires and the gap tolerance is .039-.045. Yes plugs do come pre gapped but unless you are a damn IDIOT check them yourself. The gap can cahnge during shipping.
Old Apr 2, 2004 | 06:54 AM
Daniel's Avatar
is their any gain or improvement with n e filters ?
Old Apr 2, 2004 | 08:05 AM
mansurxk's Avatar
probalby nill or negligable, unless your talking about an aftermarket air filter such as K&N, i doubt theres any improvement with a fuel filter and oil filter or whatever else, it moreso has to do with whether the filters efficienty performing
9aj9
Apr 5, 2020 12:11 AM
aminus21
Sep 12, 2015 04:53 PM
conansriver
Sep 11, 2015 10:26 AM
sdotcarter
Sep 2, 2015 09:53 PM
