help with transaxle (please guys)
Old Apr 1, 2004 | 09:28 PM
conz35's Avatar
Hey guys for those of you who have replaced your cv axles did you guys use any special tool? Im removing mine right now and im on the right side axle. I already removed the disc brakes and the three bolts that hold the axle to its mount but now it wont pry off the mount its like pressed on their. What did you guys do? I can even get a small screw driver pounded in there to start to pry. I already printed off the how to's and have been reading my manual but it shows it already a little apart from the mount not how mines is flush up against it. thanks guys.
Old Apr 2, 2004 | 05:30 AM
Ladzio's Avatar
When I did it with my uncle he simply pulled and it poped out, while I was preparing to catch spilling oil from tranny. Hope it turned all well for you
Old Apr 2, 2004 | 06:25 AM
conz35's Avatar
yeah i finally got it you just have to give her little jurk to get a space started.
Old Apr 2, 2004 | 05:10 PM
Mishmosh's Avatar
On my rusty 1995, that passenger side axle took me about an hour to get off. The support bracket was basically frozen to the axle counterpart. I had to chisel a crack and then tap in a screwdriver little by little making the separation larger and larger. I never could pull it out. Once the support bracket was separated from the axle, there is nothing holding the passenger side in--it has no C-clip like the driver's side.
I<3 A32's
Sep 10, 2015 11:07 AM
dcam0326
Sep 7, 2015 07:26 AM
Max139617
Sep 6, 2015 06:02 PM
nbstriker10
Sep 4, 2015 04:26 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
