Can i use 00-01 manual transmission on 4th gen???
Old Apr 2, 2004 | 05:25 PM
juani's Avatar
Rockin' VK56!!
I will be doing 5speed conversion soon but I'm just not sure if i can use 00-01 manual transmission on 4th gen. Can i use it?? Thanks in advance.
-John-
Old Apr 2, 2004 | 05:49 PM
5spdFastMax's Avatar
Yeah im pretty sure you can. The only difference is the driverside drive axel. I heard of a kid even putting in a 5th gen six speed.
Old Apr 2, 2004 | 05:53 PM
juani's Avatar
Rockin' VK56!!
5th gen transmission is much cheapter than 4th gen's on www.car-part.com, don't know why. and another question, will i need anything from 5th gen other drive axel???
-John-
Old Apr 2, 2004 | 06:00 PM
Mishmosh's Avatar
The non-locking tranny off a 2000-2001 is almost identical to the 4th gens. You DO NOT need a driver's side axle (unless you get the VLSD AE 2001 tranny). What you do need is a vehicle speed sensor--there is one on my 1995 but was not on the 2001 tranny I got; it has the port for it but it is capped. You just have to remove the cap and install the sensor from a 4th gen.
Old Apr 2, 2004 | 06:20 PM
Mishmosh's Avatar
BTW, if you are doing a conversion, don't you need both driver's and passenger side axles (for manual tranny) anyways?
Old Apr 2, 2004 | 06:39 PM
juani's Avatar
Rockin' VK56!!
Driver side only.
Old Apr 2, 2004 | 06:42 PM
juani's Avatar
Rockin' VK56!!
I thought i needed to have drive axel for manual transmission. driver axel for automatics fit as well?
Old Apr 2, 2004 | 07:06 PM
Mishmosh's Avatar
My bad. Was speaking in terms of a tranny swap (which I am doing) not conversion. The drivers side axle is the same for non-locking manual trannies from 1995-2001. Since you are doing a conversion, you will need a driver's side axle from a manual. Sorry for the confusion.
Old Apr 2, 2004 | 07:09 PM
juani's Avatar
Rockin' VK56!!
no problem, thanks for detailed information
CorollaULEV
30
Aug 9, 2021 08:11 PM
Matt93SE
May 24, 2019 02:58 PM
ffcbairn
Aug 16, 2015 09:29 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
