Need Help w/Wiring... like a lot
Old Apr 2, 2004 | 05:43 PM
MaxiSpeed97's Avatar
Okay, i used this post to rewire my fog lights http://forums.maxima.org/showthread.php?t=256440 so they'll work independently. I connected the Green wire w/yellow stripe of the FR Fogs relay to the Light Blue wire from the wiper relay, just like the post said.... and now whenver i put my key in left side headlight turns on automatically. also, whenever the key is not in and i turn the headlight switch my car lighter turns on, plus my fogs lights dont work at all... wtf. I really don't want to drive around during the day with one headlight on.Anyone has any ideas???
Old Apr 2, 2004 | 08:16 PM
we8345's Avatar
I'm not 100% sure, but the other post says this:
in this mod, we will tap into the wiper relay. use the relay cover again as a reference to find the wiper relay. It should be the motor-facing middle relay (or the third from the left when closed) You will need to strip back the light green wire (NOT CUT) and connect the other end of your 3-4" wire to it.
Did you connect to the light green or light blue? If it's light blue, I don't know where you plugged in... schematic for my '95 says the wiper relay has only light green, pink, brown, orange and black.
If you are hooked into light green, which end of the green/yellow wire did you attach to it? It should be the end of the wire coming from the fog light relay. If you used the wire coming from the wiring harness (it goes back to the headlamp switch), that could very well be doing the weird left headlamp thing and no fog lights.
Old Apr 3, 2004 | 08:44 AM
thanks, i'll double check everything today
mclasser
22
Nov 12, 2020 01:58 PM
BobTX10
Oct 7, 2015 08:43 AM
bernyp
Oct 2, 2015 10:10 AM
