Fuel filter replacement tip needed
Old Apr 3, 2004 | 08:54 AM
redlantrn's Avatar
Hey all. I am trying to replace the fuel filter on my 99' SE. I have replaced it before, but this time I am unable to get the filter loose from the hoses ( I can loosen both clamps, buth the hose wont budge). Anyone ever run into this before?
Thanks for any info.
~J
Old Apr 3, 2004 | 09:03 AM
Maxine's Avatar
Did you take the fuel pump fuse out and turn it over a couple of times?
Old Apr 3, 2004 | 09:14 AM
redlantrn's Avatar
Yes, as outlined in the Haynes
Old Apr 3, 2004 | 09:39 AM
1MAX2NV's Avatar
Use a plier to twist the hose. If all else falis, cut up the hose. You can buy 5/16" fuel injection hose at your local auto part store.
Old Apr 3, 2004 | 09:53 AM
nick's Avatar
grab the hose on the bottom , grab the filter and twist it back and forth - it always works for me.
remove intake and whatever else in the way - you need all the room you can get to twist that ***** !
Nick.
Old Apr 3, 2004 | 10:03 AM
redlantrn's Avatar
Thanks for all the tips guys. I'll wrestle around with it a again tomorrow.
~J
Old Apr 3, 2004 | 10:28 AM
mansurxk's Avatar
Nick.
yeah do that, put a pair of pliers on the hose, while you hold the pliers, grab the filterw ith a glove or osmething and twist it to break the "seal" and then twist it back and forth utnil it pops off, i did mine last week, was a struggle until i used a pair of pliers
Old Apr 3, 2004 | 12:54 PM
Wrightsfd's Avatar
Keep cranking the engine for a while, make sure there is NO pressure in the lines. I had one heck of a time until I just cranked the thing for about 30 seconds total and then it came off. Count to 10 three times, you are not really hurting anything, just don't do it every week.
Old Apr 3, 2004 | 03:19 PM
redlantrn's Avatar
Thanks for all your help guys. I'll give it another go tomorrow. I guess I was pulling too hard and not twisting (thats what she said!)
~J
Old Apr 3, 2004 | 03:51 PM
RA030726's Avatar
I'm nutty for Nissans
get a pry tool, they work like a charm.
Old Apr 3, 2004 | 05:04 PM
meanbean's Avatar
Had the same problem a few weeks ago. Check out my old post for help.
http://forums.maxima.org/showthread.php?t=294113
Old Apr 3, 2004 | 05:36 PM
redlantrn's Avatar
Finally got it off !. Twisting and pulling at the same time was key. You would think that filter holds like a gallon of gas the way it was pouring out of there!
No better way to spend a Saturday night!
~J
smplyamzng
Dec 13, 2015 01:19 PM
TonyJr
Aug 20, 2015 12:14 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
kirkhilles
Aug 8, 2015 10:53 AM
maxima297
Aug 3, 2015 12:50 PM
