New max! Two problems I need help with ;)
Old Apr 4, 2004 | 06:35 AM
SkoorbMax's Avatar
First is easy - the hood won't stay up. Is it easy or inexpensive to find new pistons to hold it up? Will a place like autozone have them...?
Second: that's a picture from one of the wheel wells. Each have the same issue - the boot there is cracking. How serious is this and estimated repair costs? Is it a difficult job to do myself (my skill level is only changing brakes/plugs, etc.).
BTW for those interested I replaced my 93 sentra with a 97 dark red maxima SE. 77k miles, ALL maintenance records, fully loaded 5 speed. Leather is impecable. Power seats, auto climate control, etc. Price? $6,000! I now have it and my 00 maxima. I loves them
Old Apr 4, 2004 | 06:39 AM
Conrad283's Avatar
I need a truck
The hood pistons are pretty easy to find. Your local auto store should have them, and they'll pretty easy to hold up, just make sure you have a good hood prop because that hood is HEAVY!
Old Apr 4, 2004 | 06:41 AM
Mishmosh's Avatar
I wouldn't worry about it. When it comes time for new struts, get the boot/bump stop assembly then. They aren't exactly cheap. At 65k miles, my boots were all cracked and falling apart completely. Yours actually look really good!
Old Apr 4, 2004 | 06:46 AM
Kevlo911's Avatar
Kevlo for President
If I were you, I would chekc if my CV boots are ripped. www.motorvate.ca tells you how to check,.
Old Apr 4, 2004 | 06:56 AM
SkoorbMax's Avatar
Thanks guys. I did a quick check on the CVs. they looked ok but I didn't get under the car - I know I should have had a mechanic check this out - but I was unable to due to time constraints. I did do the tight cornering at low speeds to check for clicking.
So, the recommendation would be to leave these until they start to go on me? The car drives _so sweet_. It's as nice as my 00 in driving (though it feels a touch lighter/nimbler, and accordingly a bit lighter on the highway), which is worth twice as much
Anyway I was just looking in haynes and it seems that this problem in the picture is a strut assembly, correct? Taking one apart and fixing it looks like a difficult job, but simply taking it off and replacing with a new OEM one looks easy, with an extra tool or two. Is that the case, and how much do new strut assemblys cost?
Old Apr 4, 2004 | 06:58 AM
Kevlo911's Avatar
Kevlo for President
If you are gonna replace hte struts, you might as well lower it too.
http://maxmods.dyndns.org/index.php?MaximaHandling
Old Apr 4, 2004 | 11:28 AM
SkoorbMax's Avatar
Bumpers
Old Apr 4, 2004 | 06:28 PM
SkoorbMax's Avatar
Looking for any last input on the strut
Old Apr 4, 2004 | 07:38 PM
ChrisA's Avatar
i would leave the strut alone. the boot looks pretty good. i would not suggest doing it yourself just for the boot. compressing springs can kill you. when i did my strut bearings i ended up having my brother in law mechanic do it for me and even he ended up getting cold feet halfway through it and ended up bringing it to a friends shop because they had a professional spring compressing machine to do it.
i originally bought replacement 'struts' to hold my maxima hood up for $40 but took them back before installing them. i just made a prop out of sturdy wood trim cut to length and keep it in my trunk. others on here use a mini pair of vice grips clipped to the old struts to keep it up.
Old Apr 5, 2004 | 05:24 AM
SkoorbMax's Avatar
Vice grips would have worked well...I ended up already having bought new hood lifts yesterday. $20/piece "Max lift" gas filled ones from autozone. They hold up the hood nicely.
I was reading haynes about strut replacement and you definitely do need a spring compressor from what it looks like...Maybe I'll ask more about that specifically and whether it's safe to do or not before I end up getting that strut placed, in the future when it goes on me. Thx!
matts95max
Apr 23, 2025 10:44 AM
pktaske
May 6, 2016 07:49 AM
captchaos
Mar 15, 2016 12:18 PM
MaxLife17
Sep 8, 2015 02:36 PM
pktaske
Sep 4, 2015 08:40 AM
