99 Knock Sensor - pull manifolds ?
Old Apr 4, 2004 | 05:44 PM
BobMax's Avatar
Can someone make my day and tell me that there is another way to get
a '99 knock sensor replaced without removing the manifolds ?
Thanks,
Old Apr 4, 2004 | 08:19 PM
vipervadim's Avatar
I like Maximas
only if you have a 99 california model then you will have too. otherwise:
check the how-to!!!
it's only the 4th post.
Old Apr 4, 2004 | 08:20 PM
vipervadim's Avatar
I like Maximas
there's a valve on the california models for the swirl valves
if the 12 letter of your VIN is a "V" then you have a california model.
Old Apr 4, 2004 | 08:30 PM
vipervadim's Avatar
I like Maximas
it would be good to clean out those intake manifolds though and do a little DIY port and polish on them and clean that TB as well
Old Apr 5, 2004 | 12:55 PM
BobMax's Avatar
OK... I looked over the instructions. It doesn't really lok to me like there's enough space to get in there - but who am I to doubt success.
Are they going in though the gap between the end of the intake and all the EGR ? Or a bit lower on the through the side near the egr valve ? If it's the side, any idea how much of the stuff beside the engine these folks are removing ? Airbox ? Intake ? EGR ?
Thanks for any pointers.
Old Apr 6, 2004 | 09:52 AM
vipervadim's Avatar
I like Maximas
1. if you have the stock snorkel from the airbox you will need to take it off. (2 plastic crimp bolts on the radiator support)
2. if your engine has that thing labeled #3 on the picture you have a cali model hence prepare to take your manifolds off.
3. if you don't have that "#3 vacuum thing" there look straight under the LOWER intake manifold and you will see the knock sensor, it's deep in there, or just follow the harness for it.
do you have a 99 cali spec?
Old Apr 6, 2004 | 01:06 PM
gansemer's Avatar
I wrote the knock sensor post in the 4th gen how-to sticky, and I didn't have to take any parts off my car to replace the knock sensor. I put the socket extension in just ahead of the throttle body.
I don't have any information about the California versions.
Old Apr 7, 2004 | 06:08 AM
BobMax's Avatar
That, my friend, sounds like a wager!
Looks like my MA car is CA spec. I think they adopted the CA specs a few years ago. I heard a rumor to that effect.
I think I'd have to pull most of the stuff out of the right hand side anyway to get the manifolds off, and my TB needs cleaning, so I will give it a go at getting to the KS without actually pulling the manifolds. I think that once I get all the misc hoses and such out of the way and remove the swirl linkage that I will have as much clearance as a non-CA car. I'll followup if it can be done with a post.
Comments from anyone who's tried it are appreciated.
-ReLLiK-
Apr 29, 2016 06:25 PM
ballerchris510
Sep 23, 2015 08:46 PM
ballerchris510
Sep 11, 2015 05:29 PM
