Check engine light
Old Apr 5, 2004 | 05:20 AM
Adam Cramer's Avatar
Check engine light
I had to disconnect the battery over the weekend to work on my 99 maxima. When I hooked the battery back up the check engine light and the brake lights on the dash panel are now on. How can I get them off without going to the dealer. Thanks for your help in advance.
Old Apr 5, 2004 | 05:22 AM
DemonSpawn's Avatar
If you live near an autozone, take your car there and get a free ECU scan to pull the codes and figure out what's wrong.
Old Apr 5, 2004 | 05:26 AM
Unfortunately there are no Auto Zones near me. Pep Boys and Advances Auto Parts.
Old Apr 5, 2004 | 05:29 AM
DemonSpawn's Avatar
What exactly did you do when you "worked" on your max? Could have been something you did ... no offense.
EDIT:
Try to reset the ECU ...
Disconnect the neg terminal from the battery.
Hold down your brake pedal for 2 minutes or so.
Reconnect the battery.
Old Apr 5, 2004 | 05:40 AM
I replaced the radio. Everything these days is run by a computer or has so many electronics, it forces the owner to take it to a mechanic that has a machine to read the codes. Is there a way to reset it without paying someone to do that.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
Flores94
Aug 11, 2015 12:53 PM
