Budget Y-pipe = O2 sensor code???
Old Apr 6, 2004 | 05:34 AM
MaxedOutOfCash's Avatar
Pizda Boy
I installed my budget y a few weeks back & after about driving for 25 miles the SES light came on.... i cleared it a couple days later without pulling codes & it came back on after less than 50 miles of driving...
i'm pulling 3 codes.
knock sensor
O2 sensor
knock sensor
I figured the knock sensor is popping up because of the O2 sensor code...
What could be wrong? Is it possible to break the sensor? is this normal or should I get it checked out?
Thanks,
Sam
Old Apr 6, 2004 | 06:48 AM
twiggy144's Avatar
Yes, O2 sensor are fragile and brittle. I would change the faulty O2 sensor firt. Then do a few driving cycles. Recheck the codes. There is a good change the knock sensor code would also disappear.
Old Apr 6, 2004 | 06:52 AM
Pizda Boy
so, how do i tell which O2 sensor went bad?
Old Apr 6, 2004 | 07:15 AM
twiggy144's Avatar
Oh, the 2 sensor code tells you which one is bad. Did you pull the codes with the screw-on-the-PCM-and-count-the-number-of-CEL-flashes trick?
If you have this code I can look up the description in my Haynes book tonite at home.
Old Apr 6, 2004 | 07:19 AM
DAVE Sz's Avatar
Hooooooonda.....
check the code and use this to see which one it is http://www.courtesyparts.com/A32_O2-sensors.html
Old Apr 6, 2004 | 07:30 AM
Pizda Boy
thanks guys...
i actually have a friend working at autozone & he hooked it up to the computer, that's how i know the codes... i'll pull them myself (i was just too lazy since autozone does it for free)...
Sam
mvm062
Nov 30, 2020 09:00 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
