how to replace 5-speed gear oil?
Old Apr 10, 2004 | 01:26 PM
kingrukus's Avatar
no more maxima...
Anyone have a write-up of this? The link in the "how to" sticky at the top doesn't work anymore. BTW I noticed on the bottle of my Amsoil Series 2000 75w90 that it says GL2 through GL5. Is it safe to assume that this oil is GL4 compatible?
Old Apr 10, 2004 | 02:56 PM
Nismo's Avatar
you want GL4 or mt-90(redline) equivilent. not shure of that gl2-gl5 you mentioned
remove fill plug then remove drain plug then I believe its 4.5 quarts of it but fill it up until its level with the fill plug- basically fill till it spills.
Old Apr 10, 2004 | 03:19 PM
optimus310's Avatar
this write up tell you how to replace your axles, but if you read it you will see how to drain and refill your gear oil
http://www.motorvate.ca/mvp.php/401
CorollaULEV
30
Aug 9, 2021 08:11 PM
maxinout93
Aug 20, 2015 02:17 AM
carlosvq30
Aug 17, 2015 11:32 AM
niZ
Aug 7, 2015 10:18 PM
