maximum bulb wattage on fogs ?
Old Apr 10, 2004 | 06:35 PM
blkhawk500's Avatar
What's the highest wattage bulb that can be safely (no melting of wires or cracking of lens) used for the fogs?
thanks
Old Apr 10, 2004 | 08:43 PM
(_8*(l)Homer's Avatar
55 watts max. I used PIAA 85w bulbs and they cracked the lenses. I still have them in, but there is now moisture and crap inside the foglight housings. I think I am gonna take the housings out and put some aftermarket yellow fog lamps in. I've seen some at walmart that would fit. All I gotta do is make sure they are water proof and well made, and I will throw the PIAA bulbs in there.
Old Apr 10, 2004 | 08:52 PM
myke321's Avatar
I have Koba's in mine.
Old Apr 10, 2004 | 11:08 PM
MaxiSpeed97's Avatar
What's your temperature... i just installed my 5800K's and like a minute later the passenger side went out then in another minute, it came back on... weird ****, also, i think the driver side is brighter than the passenger side.
Old Apr 13, 2004 | 03:11 PM
Brudaddy's Avatar
55watt is highest recommended for the fogs.
Old Apr 13, 2004 | 05:57 PM
ManualMaxima's Avatar
5th Gen till she dies!
(_8*(l)Homer to many lights! there is not problem with the harness meltng cause there really is not a harness. it is just a male and female adaptor. i use to have 85 watts in for alomost a year, and nothign happened at all, but i switched to a yellow bulb. you can try but some peoples break some don;t.
Old Apr 13, 2004 | 07:23 PM
ManualMaxima, where did you get the yellow bulbs? The only good ones I can find are Narva's. I need the lights so I don't hit any more animals. I've hit 4 deer 1 moose and a turkey that got smushed under my tire and I lost control of the car and bounced off guard rails. Not in the Maxima, thank God. I would like another set of fogs and driving lights pointed to the side more.
Old Apr 14, 2004 | 03:25 AM
i got the eurodesignz off ebay. i would not buy them cause they suck! i know suvlights.com have some good yellow fogs.
if you want to see alot better youshould go with hid.
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
Calabar
Oct 5, 2015 09:57 PM
