Attaching the Stillen front lip.
Old Apr 15, 2004 | 08:34 AM
DeRaNgEd's Avatar
I read through William Gay's write up on installing the Ionic body kit, but that was for the side skirts and rear. I believe that is fiberglass, I have the polyurethane lip and wanted to know how to permenantly attach it. Double sided tape is nice but my confidence does not lie within it's strength.
Nuts, Bolts, screws? What do I use and where?
I'd do a search but I haven't donated yet.
Thanks all.
Old Apr 15, 2004 | 08:40 AM
MaximaRider's Avatar
screws, one on each side of the fender and 1 screw with a washer in the center.
Old Apr 15, 2004 | 08:53 AM
C MAX's Avatar
mine just has the two way tape and screws at each end of fender. holds up just fine. 140 mph no problem.
Old Apr 15, 2004 | 09:43 AM
vsamoylov
how about the sides and the back?
Old Apr 15, 2004 | 10:20 AM
Seyser's Avatar
I dont personally have a stillen kit but my buddy had one on his Max and he attached the front lip with some 3M two faced tape. I remember when we were removing it, honestly we both were pulling like a mother just to get that thing off. Get the 3M stuff and you will be good to go!!!
Old Apr 15, 2004 | 10:34 AM
C MAX's Avatar
the same on the sides tape and screws at each end. these things are very light weight, mine havent come off yet and its been three yrs.
Old Apr 15, 2004 | 10:48 AM
vsamoylov
so will 3m hold them in place? i have my moldings on 3m tape and they are defintly not going anywhere but the aero kit is way bigger.
Old Apr 15, 2004 | 11:25 AM
C MAX's Avatar
i dont know about the aero kit but i would assume some rivots would do the trick.
Old Apr 15, 2004 | 11:28 AM
vsamoylov
rivots can hold it but if u are not carful on where u put them, u can actuall make a hole in the peice. i just found this out by doing this on a vw beetle fender. now there is a circle where the rivet is cause i used too much pressure.
The Frye
Sep 2, 2021 11:03 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
sdotcarter
Sep 2, 2015 09:53 PM
