Neep help locating ground cable from engine to frame
Old Apr 15, 2004 | 07:32 PM
st8rider's Avatar
I followed the ground from the battery to the frame to the engine. Is this the only ground that grounds the engine to the frame
Having trouble starting 98 maxima. Dealer is telling me that my ground is no longer good. They said I need to clean the ground that grounds the engine and transmission. I'm trying to make sure I'm cleaning the right ground. Any help is appreciatied.
Old Apr 16, 2004 | 05:42 AM
MrEous's Avatar
^ Jeff™
Yes that is the correct ground. It is closest to the right side of the engine near the bottom. (Looking from the front of the car.
Old Apr 16, 2004 | 05:56 AM
C MAX's Avatar
theres one more from the battery to right under the tray from there it goes to the engine. do what i did . go to auto zone buy a couple of ground cables and go straight from the battery ground to the engine
and one to the shock tower brace.
Old Apr 16, 2004 | 07:25 PM
st8rider's Avatar
has this problem happend to you????
Old Apr 16, 2004 | 11:14 PM
Nismo's Avatar
theres one from the tranny to the chassis
Old Apr 17, 2004 | 03:25 AM
C MAX's Avatar
yes when i changed my clutch on my 96 . the check engine light came on and they said i might have lost the ground to the tranny so i regrounded it and it solved my problem. i just ran a cable from the ground of the battery to the transmission.
95Maxi
35
Sep 2, 2015 10:37 AM
