***PICS*** What is this sensor for?
Old Apr 15, 2004 | 09:04 PM
OneToughMax's Avatar
I installed my ebay shorty intake the other day, and when I took out the OEM crap, there was a sensor way on the bottom. It was in one of the pipes. I just went on a hunch and decided to install it with the new intake. Here's a pic:
Here's a pic of what the sensor looks like:
I'm assuming it's some type of intake temp sensor. I haven't gotten a CEL or anything, but I have noticed that when the engine is cold and I start it, right away after I crank it the rpms will drop so low it almost stalls out, then it will come back up to normal and run fine.
any ideas????
Old Apr 15, 2004 | 09:07 PM
Taken2DaMax's Avatar
Intake temp sensor...i didn't have that in my intake for a while. After a while i got a CEL from that.
so do you think where i installed it is ok?
Old Apr 15, 2004 | 09:11 PM
zazon's Avatar
i heard just ziptieing it anywhere in the engine works dude, mine is just dangling there, no CEL yet (over a month)
Old Apr 15, 2004 | 09:12 PM
mines in the midpipe but i think it would be ok were you installed it.
Old Apr 15, 2004 | 09:29 PM
Nismotic's Avatar
Always sunny in philly
mine's dangling too. there's a very small tube i try to plug it into, but it doesnt stay. oh well.
Old Apr 15, 2004 | 11:39 PM
nostrixoxide's Avatar
If I were you then I would make sure that sensor is installed somewhere in the pipe & preferably between the Filter & the MAF. This sensor has alot to do with air/fuel adjustment it needs to be able to take readings from inside the airstream that will eventually get into the engine. Beside's, I'm willing to be it's alot cooler inside the intake tube under acceleration then just dangling there in the warm a$$ engine compartment. This sensor works in conjunction with the TPS, so make sure that you put it back in. It's not just about if you get a CEL or not. it's about air/fuel ratio management.
Old Apr 15, 2004 | 11:55 PM
Mad-MAX_SE's Avatar
Still kickin'
same here, althouhgt, mines ziptied right be side the filter (over a year)
Old Apr 16, 2004 | 02:39 AM
sryth's Avatar
We should have some clarification here. IIRC, the one you zip-tie anywhere is called the boost sensor, the one in the picture should go in the intake tract somewhere.
My Place Racing CAI had a hole for this one, but my boost sensor is zip-tied to my battery cable.
Can someone refresh my memory?
Old Apr 16, 2004 | 04:56 AM
zazon's Avatar
now i'm confused, I don't even remember what the heck i did now. I'm gonna go look at that after work.
Old Apr 16, 2004 | 06:54 AM
DAVE Sz's Avatar
Hooooooonda.....
The sensor looks very different on a 96. It's just a small resistor or FET connected between come plastic arch. If there is a hole for it obviously put it in the hole. If not just tie it to something so it doesn't fly everywhere.
Old Apr 16, 2004 | 08:39 AM
96maxdaddy's Avatar
Dude that needs to be in the hole. From your pics it looks like its after the MAF. If air can get in there it wont be measured by the MAF but the o2 sensors will read that you are getting more air and will eventually turn on a CEL
Old Apr 17, 2004 | 11:28 PM
Jonny98max's Avatar
i have the same problem....SO IS IT OK TO have it DANGLING???? if not where does it need to be ?
Old Apr 17, 2004 | 11:31 PM
happyricefob's Avatar
V^___^V
i left it between my intake adapter and my JWT filter.
Old Apr 18, 2004 | 09:01 AM
RA030726's Avatar
I'm nutty for Nissans
This is the ambiant air temperature sensor. I believe that it is for diagnostic purposes only. The only way to get a CEL is to unplug it. It does not matter where it is in the intake path to work. It can be zip tied up and you will have no drivability issuses. Heck you can unplug it and have no drivablity issues just a CEL. FYI the 95-96 are way different looking, like Big D mentioned, 97-98 are probes like shown and the 99 is a probe too but has a different plug. The boost sensor can be zip tied up too. Either way no worries OneToughMax
Old Apr 18, 2004 | 10:41 AM
DAVE Sz's Avatar
Hooooooonda.....
If he drove with it unplugged, wouldn't he be getting air through that hole? Dirty air. It's after the filter so there is nothing there to clean it.
Old Apr 18, 2004 | 11:25 AM
RA030726's Avatar
well if he doesnt have it in the hole yes it would be bad. I ment if the sensor was unplugged from the harness he wont have a problem.
Old Apr 18, 2004 | 01:20 PM
Well, the hole wasn't there - I drilled a hole for the sensor and put it in there. If I hadn't drilled the whole and ziptied the sensor somewhere then it would be fine. I just figured since the sensor came out of the intake path, I would put it back in
Old Apr 18, 2004 | 05:14 PM
Broaner's Avatar
2060lbs and falling...
We were doing Massacio's car today and noticed that on the intake plumbing. It looks very different on my 95 but I drilled and installed it on my homemade midpipe.
Note: If you unplug it you won't know how hot your engine bay is.
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
