auto tranny on sc max
Old Mar 21, 2001 | 09:52 PM
maxmze
My auto tranny slips once in a while. Does thsi make sense at all?? In talkin to a few shops they state that an auto tranny clutch slipage is normal for a sc maxima with torgue and valve body upgrades. The car sometimes slips and other times drives fine. PLEASE HELPPPPPPPPPPP!!!
Thanks in advance for your help guys
Old Mar 21, 2001 | 10:29 PM
emax02's Avatar
I have the same problem with my Clutch {5spd}
It seems to slip if I floor it before the clutch has heated up. I also noticed that it slips when the clutch is really hot after a stop and go drive. It only really connects when the temperature is in the middle,but it still slips a little then. My cure is a new cluch{which is the mail}. You may want to try redline ATF and/or get a tranny cooler. The cooler and Redline ATF should lower the temperature by 60-80 degrees. Best of luck!
Old Mar 21, 2001 | 10:49 PM
EZ's Avatar
EZ
SC ruins auto trannys fast!!! You should have a tranny cooler and don's vb mod (or level 10 tranny) to compensate
EZ
Old Mar 22, 2001 | 07:01 AM
maxmze
Re: I have the same problem with my Clutch {5spd}
I have dons vb and i use rdeline already. and the temo situation your having with you 5sp is exactly what im goin through. I already have the stillen tranny cooler with level ten torgue converter and dons vb. Can I replace the clutch alone or not??
THANKS FOR YOU HELP IN ADVANCE~!!!!!!!!!!!!
Old Mar 22, 2001 | 10:57 AM
emax02's Avatar
Re: Re: I have the same problem with my Clutch {5spd}
Well auto's do not have clutches, I think they use a torque converter or something. How many miles on your Auto tranny? How many miles has the SC been on? If you have 100+K miles it may be time to start thinking about getting a tranny rebuild. Just a idea if the problem is getting worse and worse.
Old Mar 22, 2001 | 02:38 PM
BrianV's Avatar
Let's let Steve handle this one. Where are you skimax
Old Mar 22, 2001 | 03:19 PM
Pmp-n8a's Avatar
auto's actually do have clutches...there function is not exactly the same as a 5speeds though
pktaske
May 6, 2016 07:49 AM
pktaske
Sep 4, 2015 08:40 AM
Lowered_a33
Sep 1, 2015 07:49 PM
