Improving Gas Mileage
So, my max is getting to the late 80,000 miles, and I want to do everything possible to get the highest gas mileage I can, especially with these rediculous gas prices. Any suggestions for every and all possible things that can be done.
To start I'm replacing the fuel filter and having new injector caps put on.
What else?
And what does everyone think about the K&N air filter?
What else?
A drop-in K&N got me an extra 2-3 mpg (that's a good extra 55.5) miles or so per tank of gas.
Hard launches don't help. Drive like a grandma. Keep freeway/highway cruising under 70.
Also things like the Tornado and Turbonator do absolutely nothing.
Originally Posted by ManualMaxima
of course teh seafoam in the gas tank! cleans injectors. use seafoam in your intake as welll and clean the build up. it helps. chenge o2's ensors if they are older.
check knock sensor, and make sure your plugs are good.
-if you need to change your spark plugs change them with NGK ONLY!!!!!
-check air filter
-check tire pressure
-check fuel filter
-do an oil change regularly
-clean TB for better throttle response(might help mpg since air can flow in smoother)
-use only premium gas(i heard premium gets you better mileage and it also performs better)
if i think of more ill post later. good luck
-check air filter
-check fuel filter
