Anyone know how to remove rear hub cap from rear wheel hub? pics...
Anyone know how to remove the hub cap (circled in red below) properly? I need to remove it in order to get enough clearance to install my wheels.
Screw-type driver! It's only a dust cover, a flat head will pop it right off. U may have to tap it in with a mallet though. Not sure about the wisdom of removing it, you may end up contaminating the bearing grease and frying ur wheel bearings. Wheels with the proper off-set or backspacing should not have any clearence issues. Good Luck.
Thats the thing, my rims were marked as 42mm offset...but only the box says it, I cannot see it marked anywhere else on the rim. I am so upset right now. I just got new tires mounted on them. I guess I am a fool for not testing them out first before buying them. Looks I will be forced into getting H&R spacers.
Huttig2009
Sep 25, 2015 03:31 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
RealityCheck
Aug 5, 2015 06:18 AM
