Manual Tranny Behavior - Normal or not?
Old Apr 21, 2004 | 11:01 AM
Pharoh's Avatar
I just picked up a 97 SE 5-speed this weekend. 3 things I noticed about the tranny which I don't know if its normal for the Maxima (First time I've driven a manual Max, but I've had a 95 GLE and several manual cars before this).
1) When cold, the shifter tends to "stick" for a second or so if you move it left/right from neutral before it springs back. When the car warms up, this goes away.
2) Only in first gear, I hear a slight gear whine (similar to reverse, but not nearly as loud). Once I shift into second, this disappears.
3) When starting from a stop in first gear, I hear a slight grinding noise when the clutch reaches its friction point (while slipping in the clutch). At first I thought it may be the throw-out bearing, but this noise isn't there when shifting into other gears while moving. Even if I shift into 2nd at 5 mph, the slight grinding noise/sensation is non-existent.
The car only has 49,000 miles on it, and the clutch was replaced 2 years ago or so (according to the previous owner). I thought the first 2 things would possibly go away after I did a gear oil flush, which I did this weekend using Redline MT-90 but both are still there.
It's possible that these things are somewhat common for this car, but I tend to be very over-sensitive to noises and such with my cars so I figure you guys/gals could tell me if you've experienced the same things.
TIA!
Old Apr 21, 2004 | 12:13 PM
rik3k's Avatar
I do get a 1st gear whine. It's quite noticable on mine, but seems to work fine anyways. I'm also getting the shifter-sticking. The clutch pedal does it too when it's really cold.
Old Apr 21, 2004 | 01:07 PM
puppetmastermg's Avatar
My car does the exact same thing
Old Apr 21, 2004 | 01:10 PM
Rowan's Avatar
as far as I know it's normal. I have it too.
Old Apr 21, 2004 | 01:57 PM
Rowan's Avatar
Old Apr 21, 2004 | 01:59 PM
ounkny's Avatar
as far as i know all of the above are normal. I don't think the 1st gear whine is noticeable, but it could be there.
Old Apr 21, 2004 | 02:11 PM
DerekJ212's Avatar
I have all of those but #1, but i live in Cali so its never very cold.
Old Apr 21, 2004 | 02:35 PM
jackson3837's Avatar
mine does the exact same thing bro, clutch pedal sticks alittel along iwth nueteal, only when its cold though, i think it is just our cars, i also get the whine in first, it gets worse as rpm's go up.
Old Apr 21, 2004 | 02:49 PM
MaximaNewb's Avatar
Mines does whine but i dont notice the grinding sound when starting from first. I'll try to listen for it today...
coming from a honda this maxima tranny is crap
Old Apr 21, 2004 | 02:51 PM
SzeMan4's Avatar
everything seems normal
Old Apr 21, 2004 | 04:08 PM
Pharoh's Avatar
Thanks! Its good to know that this is normal for the car... Comming from other 5-speed cars (including a 94 Sentra SE-R) that didn't exhibit any of the above behavior, I was beginning to thing there was something wrong w/ the gearbox (even though the car is very smooth while driving).
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
