MEVI installed....NICE!!!!
Old Apr 22, 2004 | 09:43 PM
1FSTMAX's Avatar
Well yesterday Slammed95 and I decided to install a MEVI on my car. I must say this really good mod. Yesterday night when we finished, we were not able to do the wiring. So we did a couple of runs with the MEVI closed and two open. I noticed that the intake tone is quieter and deeper.
With the MEVI closed the whole rev range felt smooth but lacked top end. But it felt somewhat better than the US manifold. Although I miss the 3k rpm grunt of the US manifold.
With MEVI zip tied open the bottom end sucked till 4k, that’s when it felt like it pulled. I started from a roll in 2nd gear like at 5k RPM and went WOT then car pulled to redline fast. I was amazed how much better the top end is.
With everything wired up... The power delivery feels smooth and linear, unlike the us manifold which had great mid range and sucky top end. I set the switch over point to 5300 RPM. I just pulled a rpm out of my ****, and it seems to work well.
The bad: When I wind up 1st to 6550 RPM and shift into second, the RPM drops me like around 4k which doesn’t pull as hard. But it’s not that bad it’s livable.
I have a couple of questions. I used a Harlan RPM switch. Is it OK to leave it connected to the battery, so that it stays on all the time?
What are your rpm switchover points?
Old Apr 22, 2004 | 09:47 PM
96shogunmax's Avatar
5400 here...
how you like that ball shaped vac. tank? It mounts pretty good to the fuse cover just infront of the battery. Try it there. Post a pic of it as well. I wanna see what a MEVI looks like.
Old Apr 22, 2004 | 09:53 PM
Nismo's Avatar
5,200 .
Old Apr 22, 2004 | 09:57 PM
Taken2DaMax's Avatar
congrats!!! I'm hoping in the near future i can get were you are.
I don't know about the switch wouldn't that be bad. I mean if you were to connect it to the battery wouldn't the switch drain the battery after a while? Just a question for anybody, i'm looking to purchase MEVI too.
Old Apr 22, 2004 | 10:08 PM
meccanoble's Avatar
Sports Button FTW
i got my summit set to open mevi at 5k rpm. should i be opening at 5200 or even 5400?
Old Apr 22, 2004 | 10:38 PM
optimus310's Avatar
damn Al. thats nice I must get MEVI some day.
Hope you can make it to Az so I can see that beast in person
Old Apr 23, 2004 | 04:32 AM
KMax2988's Avatar
-Yes, it's ok to leave the harlan on constant power (had mine like that for over 2 yrs, still works).
-5200 rpm switchover (5000rpm switchover off throttle, using a VAFC II now)
Old Apr 23, 2004 | 05:09 AM
deezo's Avatar
Originally Posted by KMax2988
-Yes, it's ok to leave the harlan on constant power.
Are you still throwing codes?
Old Apr 23, 2004 | 05:12 AM
I30tMikeD's Avatar
Glad you like it.
I use 5300-5400 activation. I don't know for sure because I use the summit switch and it looks to be 5.3 or 5.4 tach indicated. I did a bunch of different runs at the track one day to see what gave me the best trap speed and I found this setting to work the best.
I know what you mean on the up shift being kinda week and falling at too low of an rpm. That is what the JWT ECU is all about.
Old Apr 23, 2004 | 06:16 AM
KMax2988's Avatar
Hey Deezo, that was actually SLC98Max who was getting codes. Code free here.......so far *knock on wood*.
Old Apr 23, 2004 | 06:47 AM
stephenlc's Avatar
Coolio so whats the deal with the VAFC 2, can you make a writeup on it?
Old Apr 23, 2004 | 06:59 AM
Dave B's Avatar
Not DAVEB the parts guy
I use a 5300rpm switchover and can hear the induction noise change at around 5500rpms so I imagine the switchover is occuring in the 5400rpms range or so. Like Mike, I've seen my best runs with the activation at 5300-5400rpms.
As for leaving the rpm switch on all time, I wouldn't do it. Just wire into something that is a switched 12v source. The switch holds it's settings without any power.
With no ECU, the MEVI sure does take away the fun on WOT shifts. I remember the days of shifting at 6500rpms and landing way low in the rpms. God that sucked. The car just felt doggish especially on the 1-2. That all changed with the JWT ECU
Dave
Old Apr 23, 2004 | 07:24 AM
95stillenmax's Avatar
Im still waiting for my ecu then my mevi will be alot more fun
Old Apr 23, 2004 | 08:28 AM
maxlinegtr's Avatar
Cool alfonso!!! part of the mevi pack now....I am amazed how many ppl are doin this mod. as for the rpm switch, I would not run that thing 24/7( reputation of Harlan being problematic)..why don't you open up the hard red wire goin in the coils?
Old Apr 23, 2004 | 08:32 AM
KMax2988's Avatar
Hooks up just like the SAFC. Only difference is there is no knock sensor wire and inorder to activate the vacuum switch you have to run the VTEC output wire (pink wire) out to the positive side of the switch.
Old Apr 23, 2004 | 08:41 AM
1FSTMAX's Avatar
Thanks guys for your input. I'll go ahead and wire the Harlan switch to + /- of one of the coils.
So with a raised rev limit, let say 7k RPM. On the 1-2 shift will the rpm land around 5k?
Thanks!
Alfonso
Old Apr 23, 2004 | 08:48 AM
maxlinegtr's Avatar
Anyone heard anything on the vtec controller that we can adapt the MEVI on? i am waiting on how it came out but lost the post where it was from.Or did it come out but I just missed it?
Old Apr 23, 2004 | 08:57 AM
mitch33x's Avatar
I've had my VI sitting around since October, just need to find a weekend to install it. I'm also waiting on Technosquare to release their ECU w/ raised revs.
How long did it take you to do the install?
Old Apr 23, 2004 | 09:16 AM
1FSTMAX's Avatar
The install was not that long at all. Maybe 2hrs at the most.
Old Apr 23, 2004 | 10:11 AM
Dave B's Avatar
With my 7K limiter, I land the 1-2 around 4700rpms and the 2-3 at around 5000-5100rpms.
Dave
Old Apr 23, 2004 | 01:05 PM
1FSTMAX's Avatar
Thanks Dave!
One thing that I have noticed too with the vi, is that the engine feels like its not being pushed. It goes to redline with no problem. With the stock manifold after 6.2K RPM's the engine sounded like it was going to explode.
Old Apr 23, 2004 | 04:55 PM
JeffesonM's Avatar
living out of a maxima...
Congratulations! You'll be seeing the redline much more often
Old Apr 23, 2004 | 05:56 PM
2k3TitaniumSe's Avatar
I haven't been in the 4th gen forums too much.....so what's MEVI?
Old Apr 23, 2004 | 06:12 PM
mitch33x's Avatar
http://forums.maxima.org/showthread.php?t=217001
Old Apr 23, 2004 | 06:17 PM
Dave B's Avatar
Thanks Dave!
Yep, the intake noise becomes softer and more refined. Winding it out to 7000rpms sounds perfect. Gone is the blarring wail at 6000+ rpms.
Dave
Old Apr 23, 2004 | 07:18 PM
Mximus's Avatar
Parts needed to install the MEVI
I was looking at the MEVI from Courtesy Nissan the other day and it says that there are other parts needed to get the thing to work. I was just wondering if someone could list what those parts are since i am considering getting one and would need all off the stuff to make it work . Ive done some reading up on it and i understand the Harlan RPM switch is one of them, but i guess there are quite a few. Thanks for any helps.
Old Apr 23, 2004 | 07:57 PM
1FSTMAX's Avatar
http://forums.maxima.org/showthread.php?t=217001 :-)
Some pics of my set up:
Old Apr 23, 2004 | 09:17 PM
iansw's Avatar
I did about 20 Dyno runs when I was NA with the Harlan switch.
The best switchover point is 5000 on an Auto, 5200 on a 5spd.
Old Apr 24, 2004 | 06:45 AM
skiboarder72's Avatar
Very nice!! You have a sweet *** car
Old Apr 24, 2004 | 07:51 AM
Nismo3112's Avatar
Custom User Title
Where did you connect the rpm signal wire to?
Old Apr 24, 2004 | 08:50 AM
1FSTMAX's Avatar
To cyl number 5.
litch
123
Jan 4, 2024 07:01 PM
maxprivate
Nov 29, 2017 08:52 AM
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
BkGreen97
Apr 2, 2016 05:47 AM
lrb6805
Sep 30, 2015 08:12 AM
