foglight rewire problem...help?
Old Apr 24, 2004 | 12:04 PM
sk24iam's Avatar
Today I rewired my foglights and I tapped them into the red/blue wire going into the parking lights and I tihnk the 12v might have touvhed the chassi. Now my headlights are the only lights that work. What could be wrong? Did I blow a fuse?
Old Apr 24, 2004 | 12:27 PM
driver824's Avatar
umm.. check the fuse and dont wire to the parking lights.. there is a write up i believe at vqpower.com that the splice is all self contained in the fuse box.. literally only less then a foot of wire that is needed.. suggest that one and def check all fusses.. ALL....
next time also DISCONNECT THE BATTERY>>> saves alot of trouble..
good luck.. email me if u have any questions.. id be glad to help ya..
blake
Old Apr 24, 2004 | 12:43 PM
sk24iam's Avatar
I'm pretty sure the write up said to splice into the blue-red wire. Anyway, where are the fuses I need to check?
Old Apr 24, 2004 | 12:51 PM
driver824's Avatar
check the ones in ur car and the ones in the engine bay.. when i say check all def check all.. anything could ahve blown.. i have blown fuses taht have had nothing to do with anything that i was doin and well its not fun. when u say the headlights are the only things that work.. dash and interior is all out??? if so then thats a fuse in ur car... the main fuses are in ur egnine bay...
http://www.vqpower.com/v2/modules.ph...showpage&pid=6 follow this one .. its the one i used....
blake
Old Apr 24, 2004 | 01:33 PM
sk24iam's Avatar
The lights that don't work are the parking lights, the ocrner lights, and the foglights.
Old Apr 24, 2004 | 01:48 PM
driver824's Avatar
wel it sounds like its localized.. maybe the relay for the lights...if there is one.. try calling the nearest autozone.. those fuses are in the bay tho...
Old Apr 24, 2004 | 02:00 PM
sk24iam's Avatar
How can you tell if a relay is bad?
Old Apr 24, 2004 | 02:43 PM
fastfuriouspsyc's Avatar
hey, i had this problem, it is a fuse inside the car on the driver side fuse box. it is a brown fuse 15amp i think, it is labled interior lights or parking lights dont rememebr. but yesh i had this problem, only headlights work, no tail lights, no parkign lights, no interior lights,
ish ok man, be strong, ur max is A OK
Old Apr 24, 2004 | 03:00 PM
driver824's Avatar
well gladd to see some1 else helped.. it seems i was goin in the wrong direction.. good luck
Old Apr 24, 2004 | 03:10 PM
sk24iam's Avatar
I checked all those fuses, only one that was blown was the audio.
Old Apr 24, 2004 | 08:41 PM
try replacing it anyway, or testring the fuse on a tester because sumtimes you cant even tell they are broken, if it ish broken from a tip because they are small fuses, that has happened to me also,
Old Apr 24, 2004 | 09:51 PM
eckohb's Avatar
uh oh, thats not a good sign (from my experience). When I grounded out before, I blew my audio fuse, shorted out the wire, and now my radio doesnt work. The fusable link also partially blew, allowing me to only start the car, and only the headlights worked (sounds like a similar situation). try checking the fusable link (120-140 amp fuse in the drivers side fuse box under the hood). i replaced that, and all the lights work fine, but still no radio.
Old Apr 25, 2004 | 01:33 PM
sk24iam's Avatar
Damn... checked all the fuses on the drvers side box and couldn't find anything.
Old Apr 25, 2004 | 01:38 PM
driver824's Avatar
sorry man def try brining it to a machanic... have them test ... maybe even a dealership...
blake
Old Apr 26, 2004 | 04:58 PM
sk24iam's Avatar
Anyone have anoy toher suggesitns before I try to ahve this professionally looked at?
Heat0212
Oct 24, 2020 12:36 AM
Sir Tilus
Mar 22, 2016 01:49 PM
ricky7780
Nov 3, 2015 03:22 PM
Excalibur23
Oct 13, 2015 04:33 PM
Hdnseek
Sep 9, 2015 05:55 AM
