Shiftknob too high??
Old Mar 22, 2001 | 07:10 PM
dntree
I just bought a 97 SE 5 speed and the shiftknob is too high. Does anyone feel the same way? I just cut the shifter by 1" and replaced the **** with a MOMO air racer. Looks great. Feels great. More comfortable.
Old Mar 22, 2001 | 07:23 PM
_DRU_'s Avatar
interesting...
what did you cut it with? did you have to make new grooves to put the Momo shifter on? more details please.. i feel like im driving a bus at times.
Old Mar 22, 2001 | 07:38 PM
dntree
Re: interesting...
I cut it with a Dremel rotary tool. It took about 10 minutes because I didn't want to break the bit. Make sure to cover everything due to metal shavings flying off. The MOMO shiftknob comes with a variety of sleeves that will fit on the shaft of the shifter. It also comes with allen screws to lock down the shiftknob.
Old Mar 22, 2001 | 08:07 PM
Daniel B. Martin's Avatar
Dremel is a good tool
Originally posted by dntree
I cut it with a Dremel rotary tool. It took about 10 minutes because I didn't want to break the bit. ...
I've had good results cutting all sorts of things with the Dremel rotary grinder using one of their abrasive cut-off wheels.
Old Mar 23, 2001 | 05:11 AM
ejj's Avatar
ejj
Most short throw shifters will also fix it. I installed a SMC and the shift **** is [I]quite{/I] a bit lower.
If you want before and after pics let me know.
Old Mar 23, 2001 | 06:43 AM
Whitemax's Avatar
Disco Biscuit
I cut mine with a hacksaw. I chopped off about 2 and a half inches on mine and it seems just right. The STS is great, but if you want a free mod( and we all do!) choppin the shaft is great.
Old Mar 23, 2001 | 06:50 AM
maxkid77's Avatar
how would you make the grooves if u wanted to put the stock head back on?
Old Mar 23, 2001 | 06:53 AM
Whitemax's Avatar
Disco Biscuit
You can't use the stock **** after you cut it. But it does give you a great reason to buy a Momo
Old Mar 23, 2001 | 10:31 AM
Kevin Wong's Avatar
actually
The shift **** is not high at all. It's just the shifter and fulcrum itself. I had a razo shift **** on my 89 Mazda 626 and I replaced it with my 97 Maxima SE shift **** and it actually reduced the overall height. I'm about to order a Pacesetter STS from JC Whitney ($60) to correct the shifter problem.
jmlee44
Oct 2, 2022 02:13 PM
Apr 16, 2020 05:15 AM
maxinout93
Oct 31, 2015 02:04 AM
