60K Tune Up...
60K Tune Up...
I'm about to embark on the 60K tune up and this is what I'm going to do so far,
Flush coolant system
Change fuel filter
Rotate tires
Change spark plugs
Change In-Cabin microfilter
Get the squeaking out my brakes
Check/replace belts
Change AT fluid
Change air filter
Would there be anything else to do? Also, I'll be ordering parts from Jerry Rome Nissan (30% off) and will order these parts,
Fuel filter
NGK Copper plugs
In-cabin microfilter
Anything else I should get? Thanks for the advice.
Change fuel filter
Rotate tires
Change spark plugs
Check/replace belts
Change AT fluid
Change air filter
Fuel filter
NGK Copper plugs
clean:throttle body
IAC valve
EGR valve
IAC valve
EGR valve
Change fuel filter
Rotate tires
Change spark plugs
Check/replace belts
Change AT fluid
Change air filter
Fuel filter
NGK Copper plugs
Change fuel filter
Rotate tires
Change spark plugs
Check/replace belts
Change AT fluid
Change air filter
Fuel filter
NGK Copper plugs
litch
123
01-04-2024 07:01 PM
