97max gets hard time starting I get a code 05 03
Old Apr 29, 2004 | 07:58 PM
Byndes's Avatar
Hi, my 97 max has a hard time starting. I was getting a massage that o2 sensor had a problem but not anymore. I get a code 05 03 which is a “CRANK POSITION SENSOR” there is two of them which one?? My clutch was replaced with a starter last week. Any ideas how to check which one and how to change one or both of them. Any suggestions?
Old Apr 30, 2004 | 02:27 AM
njmaxseltd's Avatar
It's most likely Crank Position (POS) and it's located on the transmission bell housing. Down under the car twards the front. Makes sense being you had a clutch installed and that sensor would have been disconnected while the tranny was dropped. That sensor is know to cause hard starts when it dies.
Old Apr 30, 2004 | 06:17 AM
Byndes's Avatar
i will take the car back to the shop to check it out. I hope they won't burn anything else again like they did with my starter motor. Also car bearly pulles when i flore itt. what could that be? if it would be a KNOK sensor would diagnostics give me a code for it/?
Old Apr 30, 2004 | 07:08 AM
maxhopper97's Avatar
Code 05 03 is the right bank front heated O2 sensor, not crank sensor. With the O2 problem you are running rich on that side of the motor, dumping raw fuel down your exhaust which will eventually ruin your cat.
kjlouis
Nov 24, 2018 06:09 AM
MaximaRaj
27
Oct 2, 2015 07:31 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
doobadoo
Aug 15, 2015 06:43 PM
Balkins
Aug 12, 2015 06:39 AM
