suspension noise on pot holes
Old Apr 30, 2004 | 05:02 AM
dss42's Avatar
I drive about 400 miles a week most on highway pot holes, lately I have been hearing a noise on every pot hole from the whole front like a clucking noise "click clock like something is moving" I am not sure what it is could this be my motor mounts going bad? or something else.. I never changed my control arm bushing nor the sway bar bushings could eather be it?
Old Apr 30, 2004 | 05:08 AM
helloiamphil's Avatar
is ur car dropped or factory?
Old Apr 30, 2004 | 05:32 AM
dss42's Avatar
Eibach + Tokico blues for a long time.
Old Apr 30, 2004 | 07:50 AM
dss42's Avatar
bump? ........
Old Apr 30, 2004 | 11:34 AM
atpham89's Avatar
You might want to take a look and the strut mounts and bushing. Also check your tokico blues because they break down overtime.
Old Apr 30, 2004 | 12:44 PM
drewm's Avatar
If it's a clunk, it's probably the nut at the top of the shock tower that's loose. Tighten it back up and you should be good. I'm not sure what the torque spec is on that nut, but I bet someone else here does.
Old Apr 30, 2004 | 01:37 PM
bruteMax's Avatar
maybe it's the top of your coil springs rubbing against each other? I think I have that and am going to wrap some rubber hose around the back pair (where I think the sound is coming from), to address that issue.
Old Apr 30, 2004 | 05:59 PM
dss42's Avatar
any more ideas? What other bushings usually go bad after time? 103k on the car.
Old Apr 30, 2004 | 06:38 PM
BEJAY1's Avatar
Conecarver
Could be a couple things incl the ones mentioned earlier. While the car is parked open the hood & try pressing down the fender from the side right next to each strut. Do it really hard like you would with a bumper/shock test. Get the car bouncing if you can. Does it make the same noise? Is the top of the strut moving around at all?
Old Apr 30, 2004 | 06:44 PM
maximus_pr's Avatar
strut mounts maybe?
Old May 2, 2004 | 06:55 AM
dss42's Avatar
I changed the sway bar bushings, stab bushings, and links bushings. Sound went away the only thing I hear now is when coming in and out of driveways a small noise like a bushing is stretching. I think it might be the control arm bushing?
Old May 2, 2004 | 08:03 AM
Angelr34's Avatar
if it does make that noise then what does that mean?
my car makes the same sound
im dropped on gcs
Old May 2, 2004 | 08:36 AM
Tony D.'s Avatar
My uncles max had a similar problem with clunking which seemed to be coming from the passengers wheel well. After months of searching one mechanic found that the control arms's ball joint was really worn down and was clunking around in the socket. it was a basically cheap fix too about $180 w/ labor. BTW his max has a little over 100k miles.
Old May 2, 2004 | 08:38 AM
dss42's Avatar
im dropped on gcs
I think that is normal.
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
uttadms31
Sep 30, 2015 05:24 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
