Gona drop it!
Old Apr 30, 2004 | 12:07 PM
XeroX's Avatar
Hella internets
Gona drop it!
Ok.. i got my KYB AGX struts...and i just sent payment in for my Ground Control Coil-overs...
I wana drop the max as soon as i get them, but im wondering what i should replace when i do...what is necessary, what is recomended? etc...
I want these struts to last me along time and i dont wana take em out after i find out i should have replaced a bushing or something.. i want to install it and leave without worries...
what shall i do to accomplish my goals?
Old Apr 30, 2004 | 12:20 PM
aznsap's Avatar
i would actually like to know also, i'll be putting in tein s techs and tokico illuminas this summer. btw i have a '95 gle w/ 78k miles. i know there's been threads about this before, but the search function is broke. the only things i can think of right know we should consider getting:
motivational rear strut mounts
and the kyb dust boots (or OEM and cut the bumpstop shorter)
Old Apr 30, 2004 | 12:56 PM
XeroX's Avatar
Hella internets
yeah i have a 95 GXE with 112k miles...
btw im dropping my car about 2 inches all around... cutting the bump stops eh? is that recomended? how do you do it?
Old Apr 30, 2004 | 01:59 PM
Nismo's Avatar
my bumpstops are cut down to like 1 inch
Old Apr 30, 2004 | 04:51 PM
XeroX's Avatar
Hella internets
bump... what do i need to get?!
Old Apr 30, 2004 | 04:56 PM
4DRSpeed's Avatar
Project Ruby......
I have Sprints sitting in my garage, and on the way are my Illuminas and KYB Dustboots. Don't know what else to really get, if your CV axles are shot I'd replace those while your at it.
But if your going 2" drop like I am, I would suggest some KYB Dustboots or cut the stock ones. You'll need all the travel you can get so you don't bottom out badly.
Old Apr 30, 2004 | 05:46 PM
XeroX's Avatar
Hella internets
how do you cut the bumpstops? and is it necesarry to replace the bushings on the strut towers?
Old Apr 30, 2004 | 06:04 PM
ohannon7's Avatar
Id kinda like a little bit of guidance on cutting the bumpstops too since I will be putting on coilovers w/ in a week or two. As far as boots, my stocks are pretty shot, I think I might try to get replacement factory's if they are cheaper and Im hoping camber wont be an issue
Old Apr 30, 2004 | 08:39 PM
phenryiv1's Avatar
Mod her. Ate her.
Several points here:
1, coilovers do NOT require strut boots. There is nowhere to attach them.
2, if you have ground controls with AGX you must grind or file the (6 or 8) sided flange off of the strut body. The coilover sleeve needs to slide onto the strut body, and the flange gets in the way.
3, the KYB strut boot info (for the rest of you) is in the FAQs. The bumpstops are precut.
4, for coilovers, you cut the bumbstops OFF OF the OEM strut boots and use JUST the bumpstops, not the rest of the strut boot. You may trim it ta the narrow part of the neck to add a bit of suspension travel.
5, For all applications, I would replace the strut bearings.
Old Apr 30, 2004 | 09:14 PM
ohannon7's Avatar
wow, im gonna have to take a closer look at the suspension. Its just kinda a pain in the @ss since you dont wanna always take it all apart, or have it just sittinng in pieces for a week or two while you get all the parts you want. Good info though, thanks!!
Old Apr 30, 2004 | 09:32 PM
phenryiv1's Avatar
Mod her. Ate her.
The coilovers that I have worked with do NOT use strut boots, but in your application I would re-use the bumpstop portion of your busted OEM boots. If they are messed up, I would definately salvage the bumpstops.
Old Apr 30, 2004 | 09:45 PM
happyricefob's Avatar
V^___^V
u'll probably need motivational rear strut mount to get that extra suspension travel. i know you are going low-baller style so i recommend getting that....
Mar 12, 2020 12:06 AM
jonreidhead
Jan 6, 2016 09:38 AM
Turbonut
46
Oct 21, 2015 08:28 PM
maxima-junky
Oct 7, 2015 06:13 PM
Redfox
Sep 28, 2015 10:41 AM
